Power FC
Guest hongo_rules
Hi,
Have been looking into getting a Power FC for my R33 GTR.
Second hand if possible but not having much luck.
Best price new I have found so far:
http://www.greenline.jp/specials.php
Has anybody had any experience with them? I notice that they have an Australian agent.
Their agent has been very helpful but just wanting to know if anybody has dealt with them in the past.
Any other recommendations?
Kind Regards,
TG.
https://www.sau.com.au/forums/topic/18069-power-fc/
  • 4 weeks later...
Hi,
I'm selling my PowerFC and hand controller as I return my car to stock to sell it.
I'm asking 2Grand with the hand controller and what is probably the best tune I've heard off on a near standard R33 GTR. I have a HKS cat back exhaust. (255kw at the wheels at 1 bar).
Only minimal massaging would be required to spec to your engine if your car is stock.
I'm definately selling it in the next week or so.
Also if interested I have a set of 80mm meters (Z32) which is a common upgrade with Powerfc for GTR's. It's a selctable option in the computer to read the different voltage etc. I just never got around to fitting them.
normally 350 a meter, 700 for the set.
If you want the lot you can have it all for 2.5K
Send me a PM if you're interested, I'm in sydney.
Serious offer.
Sebaz
https://www.sau.com.au/forums/topic/18069-power-fc/#findComment-419311
Guest hongo_rules
Unfortunately by the time that you include shipping costs from Sydney it may not be worth it. Thanks anyway.
I have decided to go with Greenline, their prices have dropped even further for July:
http://www.greenline.jp/specials/julyapexi.php
Have had awesome customer service with them so far in terms of response times and information. Have had a few friends purchase off them so I don't think there is a problem.
https://www.sau.com.au/forums/topic/18069-power-fc/#findComment-421217
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
