It is with great sadness that i announce the departing of my beloved 1989 R32 GTST Type M 4 Door. I've had the car for just over 12 months, and have loved every minute of it. I went from a 1992 Suzuki Swift GLX sedan 1.6L, to the gtst, and mark my words..what a change! powerless 1.6L front wheel drive (which still chopped civics!) to a 2.0L turbo'd rear wheel drive with completely different handling characteristics, and power dynamics. I am at this stage swapping the vehicle for a 180sx which i will be turning into a drift pig. She will be missed. I will continue to be a member of this site because i will eventually be getting my hands on a gtr. Every time i see a fellow skyliner i will be sure to wave/flash lights/honk because all of you guys are awesome and have helped me out of some sticky situations.
I thank you all so much, and hope to see some of you guys on the drift track!
https://www.sau.com.au/forums/topic/180765-it-will-be-missed/
  • Replies 43
I agree with Wink, you could turn your 32 into a drift car too. If you do turn your 32 into a 'driftpig', you can use the money you were about to spend on the 180 and put it towards your wedding. If your wedding is still going ahead, I'd say concerntrate on your soon to be wife and get a house, but that's just me. It's your life and if you want the 180 or 34 gtr, go right ahead mate.
Good luck with everything. :)
yeh thanks Grant..
NG0387 - it's obvious that you are young and will make your own mistakes/decisions.
I'm assuming the 180sx you got was the one with the ca18det in the sale section of this forum?
he was asking $7.5K.
I'm hoping that you got at least $4K on top of his car for your R32 4 door.
the other thing is, you had a 4 door R32 skyline.
it's pretty much the "IN THING" in that crap they call drifting, which you want to do.
You're car would have been so much better at it then a ca18 180sx with FMIC and a pod.
The skyline has better brakes, more powerful engine, etc.
If you come to a public forum and make posts about whatever you want to talk about, you are going to get peoples replies.
if you don't like it, then that's too bad.
everyone here is posting their own opinion/experience.
You started here with "I want a 1000kw R34 GTR" and we know where that went.
then you swapped your skyline for a ca18det 180sx?
That just seems stupid to me.
not to mention you calling a 180sx with pod and fmic a drift pig.
I'm not about to baby what i think just so it doesn't hurt your feelings.
Toughen the f*k up princess
same goes for your husband.
Edited by GTST
yeh thanks Grant..
well before u go assuming things its not the one thats for 7.5k...and its got an SR20..and i never claimed that a 180 with a FMIC and pod was a drift pig..what i said was i wanted to turn it into a drift car which i have called a drift pig....and as for the GTR, yes they are my aspirations, i want a powerful R34 GTR, but thats my decision and it doesn't concern you. if u dnt agree with it fine but keep it to yourself. clearly no one hear cares
Here's what I'm saying:
Shut the f**k up, 'GTST'.
You obviously have it in for 'NGO387', so why not just stay out of his threads, and save the rest of us from reading your poor attempts at hassling him.
Agreed 120%.
You've assumed everything and know nothing yet your giving him a hard time about things you dont know about.
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
