Gday,
Just wondering if anyone out there has bought (or knows where to get) a good indoor car cover. By good, i mean one that is designed to suit the needs of a finatical car enthusiast. I dont need one that is for outdoor use, as it will be in my garage. Looking to spend under $200 if thats possible.
And yes, i have tried Auto barn, Supercheap etc. I just cant seem to find info on them in Australia; they're all in the states.
Thanks,
Shaun.
I find that the ones they have for sale at supercheap, autobahn etc are pretty shit. I don't know if all car covers are like the ones they sell, but when you take the cover off, a lot of dust and sand gets stuck to the car which means it can get scratched easier.
All those covers are the same.
We have a VERY expensive one on our Chev, dust still goes through.
We got those thick winter type sheets and stitched them together as a first layer, they sit on the paint, all nice and soft, then the other cover goes over it.
Can't remember the name of the material, but it's those really thick winter sheets etc. Others will know.
i would like to get one of those inflatable car covers./ you drive into it and blow it up. really i think its the best way to keep the dust off. i havent been able to find anyone in oz that sells em.
I actually ended up buying one on sale at Super Cheap for $149. Its for indoor use only (its made from polar fleece fabric which is really soft) and fits like a glove! Im really happy with it.
The other indoor car covers are too expensive as all the ones i found are over $350.
Shaun.
just get a few exhaust fans fitting in the garage and leave them running all the time. that will suck up a lot of dust. then put plastic down the sides and make sure it has plenty of static electrcity. that will make it kind of like a spray booth.
^^lol thats alot of effort just to keep a car clean :rofl: I use one of the autotechnica covers, the ones in the red box, can't remember what they are called. For my car which sits outside. Works very well, can't see any reason why you wouldn't use it inside either....
Shaun.
Does dust and sand get stuck to it when you take it off by any chance?
I dunno, i havent taken it off yet. I can see how it would though; you'd have to store it in a clean place (it comes with a bag with a zipper), and you'd also have to make sure that the car is clean before you put it on again. Its not a problem for me though because my car isnt a daily driver.
Flanelette sheets are what i think you are referring to. :P
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
