Hey guys im attempting to change my starter motor this weekend. Not very familiar with rb20 engines but i do have some knowledge on mechanics. Is it a easy enough swap over? can it be done by the backyard mechanic? lol is there anything i should know about that will save me from cursing all morning? tips/help/advice
thanks in advance
Dave
https://www.sau.com.au/forums/topic/180863-replacing-starter-motor-rb20/
disconect your battery to start of with
it preety easy to do you will need a 12mm spanner and 14mm spanner 10mm spanner for battery
all you do is disconect batt, remove wires on starter one will be a 12mm nut and the other will be a push on wire
undo two 14mm bolts and pull it out
and install is reverse just make sure yoou compare your old one with new one to make sure there the same
it is preety tight to get your hands in there but shouldnt take you any longer than a hour to do it.
and its easyer from the top than the bottom
well gave it ago today, with no luck, and the short spurt of rain didnt help either lol. I just couldnet manage to undo the one bolt. managed to get the bottom one off piss easy but the top one, couldnt get my hands or a spanner in there. is there a special shaped spanner or socket piece i could you to squeeze it in there?
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
