The jerking on downshift is basically independent of pucks. It's all a matter of driving style. The blip is called "heel-toeing'. The reason you get the jerk is that the engine and gearbox are not spinning at the same speed for the gear you are selecting. Heel-toeing matches the engine speed to the gearbox (road) speed.
https://www.sau.com.au/forums/topic/180905-5-puk-or-9-puk/#findComment-3289078
3 puk - http://clutchnet.com/photos/3button_solid02.jpg
5 puk - http://www.mpautoparts.co.nz/images/PukPanel.gif
as u can see, the more puk's the greater contact area on the flywheel and easier to drive it will be.
https://www.sau.com.au/forums/topic/180905-5-puk-or-9-puk/#findComment-3289966
feel is best described as where in the peddle travel the clutch starts engaging and how suddenly.
With OEM clutches... they have no feel really... once you get a button you'll learn all about feel for the clutch :rofl:
thats for sure..
I use an Exedy Hyper Carbon Twin plate.....kinda crazy if u drive it in heavy traffic.
https://www.sau.com.au/forums/topic/180905-5-puk-or-9-puk/#findComment-3292113
ok.
i guess i have a final question.
Out of the clutches below, which one is the easiest to drive??? and when I down gear, there will not have a shudder...
-5 puk ceramic button
-9 puk ceramic button
-cushion button
select one from the above. the main important point is that I do not want the car to shudder when down gear...
Cheers. :thumbsup:
https://www.sau.com.au/forums/topic/180905-5-puk-or-9-puk/#findComment-3296889
Hear this
ALL CERAMIC/BRASS MATERIALS WILL SHUDDER ON DOWNSHIFT IF ENGINE REVS ARE NOT MATCHED!!
Its due to the nature of the materials used...doest matter how many pucks or whatever. if you do not rev match, then your pretty much slipping the clutch everytime you downchange.
But, as for most driveable.. a 9 puck cushioned button will be the most driveable
https://www.sau.com.au/forums/topic/180905-5-puk-or-9-puk/#findComment-3297307
Hong, going back a few posts a cushioned clutch has nothing to do with a sprug center rather a cushioning between each side of the clutch plates. A conventional button uses a single sheet of metal with puck either adhered or riveted to it. The Cushioned plates use two plates with a "spring" in-between. This "spring" takes the initial shock of the engagement rather then other driveline components such as gearboxes and diffs :laugh:
Bacially if the vehicle is mainly a daily driver, and a puck clutch is your preference, I would strongly suggest using a cushioned item.
The sprung center is purely a sound/vibration dampener.
If you need any further information or pricing on Genuine Exedy Clutch Kits drop me a line.
https://www.sau.com.au/forums/topic/180905-5-puk-or-9-puk/#findComment-3297558
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
