Ok here is the story & YES i have read all the threads i could find on topic
I have a 97 s2 Gts-T
Mods are:
8.5psi (Turbotech)
R34SMIC
Pod
EVERYTHING else including exhaust is std
When i got car always had a slight pop on idle but never missed through rev range....anyway as i had changed g/box & diff oils, all filters etc since i go car i though id change the plugs as god knows how long they had been in there...got a set of iridiums heat range 6 (originals were 5) & threw them in...straight away it started to hesitate/miss at 4500-5000rpm so i did some research on here & regapped to 0.8mm & it made a hug difference but miss was still there on idle & in cold it would hesitate occasionally but i lived with it...then it started getting worse so i thought time for splitfires
whacked them in & presto miss gone on idle & no hestitation...but first time i drove it in colder weather at night its back???
Then I noticed when i give it a good kaning it tends to go away (as it does in the warmer weather) so im starting to think maybe going from a heat range 6 plug from 5 might be the whole problem as it seems when its cold they do not fire properly but when its warmer or after i drive it hard it seems to be fine
Maybe i should go back to a heat range 5 & my car is not modded enough to benefit from a heat range 6 plug & infact running worse
Any thoughts as im stumped?
https://www.sau.com.au/forums/topic/180944-misfireplugscoilpacks/
you have said that they are 0.8mm gap but how old are the plugs? and what sort are they?
you shouldn't have to run the smaller gap with splitfires.
i would also suggest not running too much boost with the stock exhaust. it is a bit restrictive and will keep more heat in the turbo.
the reason why it goes away if you fang it is that the plugs are fouling. your o2 sensor may be a bit stuffed and causing you to run rich at low load which is fouling the plugs. then when you fang it the plugs are cleaning themselves.
NGK Iridiums & they are only 3months old
thats what i though hence why i am stumped
yea thats why im at 8.5psi & not 10-12psi
but i get my usual km out of a tank? if o2 sensor was stuffed wouldn't that affect my kms per tank?
not if it was stuffed when you got the car. the hotter plugs you were running got to their self clean temp easier so they could burn the extra fuel easier.
and how many kms old are the plugs? not age sorry.
pull them out and have a look and have a look and see if they are fouled up (all black and sooty). if they are then it is running rich and it would be worth testing your o2 sensor.
ahh i see & does make sense
plugs done about 2000-3000k max
I heard o2 sensor should be changed at 60,000 anyhow? that true? if so im due for one as i just have passed 70,000
regardless i should change plugs yea?
THANKS
try changing the plugs to a set of copper ones (bcpr6es) and see if that makes a difference (they are only about $4 a plug, so won't break the bank). it also depends on if the o2 sensor was even changed when it was supposed to.
try disconnecting it and see if alters your fuel economy.
cheers
what gap? the std 1.05mm or gap down to 0.8mm?
Ok i think i may have gotten wrong iridiums originally & when i re-gapped i think i might have damaged the tips so i have a new set on the way which are already 0.8mm & i also have a new NTK o2 sensor on the way as it prob has never been changed (Thanks Kudos Motorsport) so will throw in new sensor & plugs when i receive & hopefully problem is solved....
if not i wont know what the hell it as i would have changed coilpacks, plugs, o2 sensor & would only really leave AFM or CAS in the equation
  • 1 month later...
I was talking to a mechanic the other day, and he said you are better with "Normal" plugs.
We were discussing a similar problem with my drive at the time.
His opinion was that the Platinum ones, once they get a kicking, dont seem to recover, and need changing again... !!!
Makes me wonder why I am using them. at the price they are?!?
Now I am confused?!?!...., I thought they were the dogs goodies, but now...
Anyone else know better, and can substanciate it?, 'cos I'd love to know which way to go.!
BTW, the flat spot on mine is at 5500 RPM. @14, 18 & 22 PSI (not using any more than 14PSI at the moment BTW!)... Kinda wrecked the 24PSI attempt for me that day!!
Mr Dyno said it was the coils, but I noticed a noisy Fuel Pump on Sunday eve, and someone said if it had been run dry, then it could have been damaged(it's about 250Km old now).
My thoughts are, if it was noisy, and a wavering noise was coming from it, there could be a problem, but the Dyno never picked up a lean situation, or any fuelling problem.
I am going to try the ones that Just Jap sell... the ones with 10% extra voltage. Seem a better price, and offer more spark too, I'll update when done.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
