bored?
wanna listen to scanners online?
enter this url into either winamp or vlc
http://www.waix.net:8000/scanner
(with vlc its under open/open network, then enter url)
then download this document for reference to police codes (which is slightly out of date):
police_jobcodes_2006.pdf
or you can visit
http://warsug.info/viewtopic.php?t=3 and also check out the forum
its cool to have it on in teh background and everynow and then something interesting will happen
(the scanner unit itself drops out after 2 sec of no communication, and then will pick up anything it hears - police, fire, ambos, bus/train)
https://www.sau.com.au/forums/topic/181142-bored/
I used to have a scanner, i bought it from tandys for 200 bucks, Bloody good to listen to on the weekend nights. I heard things from kids throwing fire crackers at cars, crashes, police chases, a riot in cannington with over 100 people, a guy going from door to door asking for money, ALOT of domestics, and one where a skyline and a ferrari that were drag racing along the kwinana fwy at over 170kph across the narrows haha and one of a old commodore doing bout 150 through a booze bus haha what an idiot, and heaps more.
https://www.sau.com.au/forums/topic/181142-bored/#findComment-3294295
A 'good' uhf will have this facility... at my old work i was having after work drinks listening to police freqs.
Best one I heard was about a 'ford falcon versus garage wall' lol... car chases are fun too...
Police have supposedl;y been going digital since pre-200... system has to many flaws, not happening anytime soon.
https://www.sau.com.au/forums/topic/181142-bored/#findComment-3308735
When i picked my 32 up from the car yard it still had the standard radio/cd player in it from japan, their radio frequencies must be close to our emergency frequencies as i could hear ambulance chit chat through it. . . . nothing exciting happened :)
https://www.sau.com.au/forums/topic/181142-bored/#findComment-3308810
    • Any advice? Yes. Learn to make your own lines, they're actually pretty easy and you can make hard lines, flexi lines, whatever you like, perfectly fitting to your application.  https://www.efisolutions.com.au/    sell a huge range of hoses, fittings, everything you need. You might have to outlay a bit in the beginning (eg I bought a 5 metre roll of stainless tubing that I've used less than a metre of) but still cheaper than buying premade shite hoses that sort-of fit.
    • If by axles you mean driveshafts, they're supposed to have play in them. They are not hard to recondition, it's just pulling apart the cv's, cleaning them and regreasing, fit new boots. I've only rebuilt one set and there was fk-all wear in them, still running just fine 8 years later.
    • Note, the aluminium bit that screws in the end that you have to remove to dismantle the rack is single use as it's punch-marked, it will strip when you unscrew it, and then you have to flatten the notch in the steel rack body, screw in a new aluminium end when rebuilding, then punch-mark it again once assembled. it is also 'somewhat tricky' to refit the rack>steering wheel linkage gear as it needs to be set to the right preloads etc. A rebuild is probably something that's better just given to a steering shop for a couple of hundred, unless you're mad-keen to do it yourself.
