Hi All,
Im new to this forum and due to pick up my ER34 this weekend (very excited!!!) and was wanting to know if anybody has debadged there skyline?
Im looking to debadge the badge on the bonnet & nissan, skyline and R34GTT badge on the boot.
Looking for some tips, instructions or pics if anybody has done it before.
Any info would be much appreciated.
Did a search on this forum but couldnt find anything.
Sorry if its a repost.
Thanks.
Rob
https://www.sau.com.au/forums/topic/181145-debadging-r34/
Not sure if I've seen anyone take the badge on the bonnet off, but to take the others off, you would normally use a heat gun or a hair drier to melt the glue and then use some fishing wire to 'cut' the badge out (if you know what I mean).
https://www.sau.com.au/forums/topic/181145-debadging-r34/#findComment-3291792
Thank you all for the advise i shall definitely try it, and i wont be holding onto the badges when im done so ill post again when i want to get rid of them.
From what i can remember the skyline badge on the boot was a gold colour......im picking the car up this saturday so ill confirm once ive picked it up.
thanks again
https://www.sau.com.au/forums/topic/181145-debadging-r34/#findComment-3292830
Fark, that car in your signature is hot!!! Get your car looking like that and post up some pics. :)
Didnt know they made a GTR kit for a 4door or does a 2 door kit fit on a 4 door anyway?? Hmmm...
Post sum pics when its debadged, im thinkin of doin the same but bot sure how it'll look so u can be the guinea pig :(
https://www.sau.com.au/forums/topic/181145-debadging-r34/#findComment-3295403
GOLD!?!?! Interesting....I want to make my 4dr look like that as well,but still dont know what side skirt is that...it looks like east bear on the other pic,but this pic looks a bit different...BTW,have u got the LED tail light~~~
https://www.sau.com.au/forums/topic/181145-debadging-r34/#findComment-3297249
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
