There are many different incarnations of the TD06 20G. There is a TD06-20G, TD06H-20G, TD06N-20G, TD06S-20G, TD06L-20G and TD06L2-20G. Then there are the optional turbine housing sizes as well. There are 8cm, 10cm, and 17cm housings available for the 20G based compressors. So there are 6 different turbine wheel options to mate to the 20G compressor plus the 3 housing options. There are also compressor housing options but the 20G wheel performs about the same in all of them, even the little TD05 based housing.
There are also different versions of the 25G (T67) although not as many. TD06H-25G, TD07-25G and TD07S-25G. I think there is one more but I'm not sure of the name. Turbine housing options for the 25G are as follows. 8cm, 10cm, 17cm and 22cm. So 3 or 4 turbine wheel choices and 4 housing choices. The 25G is available with a 4 inch inlet or 3 inch inlet on hte cover.
Some of these may not apply to your application but maybe helpful for the archives or just in general.
jeff
Ok... here's some pics and some more info. its a TD06H-20G. On the compressor wheel its got the trust part number: 49179-52010 which is different to the part number on the trust blue plate (49179-01190) It also has 0/8 and H9 written on it. The exhaust housing has a Q then DUCM then 2 then 6G also 7 9-14400. Dunno if this means anything... any more idea's of HP and spoolup time?
Originally posted by sidewaymambo
Bloodline..my TD06-25G (T67) has 16cm turbine housing ..
Ahh.. another choice that I wasnt even aware of. Thanks for pointing that out.
Now on to the turbo itself. I cant say with any certainty at what rpm the turbo will spool on your application as I am not familiar with the performance of that turbine housing. I will say that the TD06H-20G in an 8cm turbine housing is capable of 450+whp at its limit on a 2.0L engine. I have made right at 400whp on the smaller TD05H-20G 7cm on a 2.0L. The 20G compressor is rated at approximately 44lbs/min depending on who you ask.
Now to the turbine wheel. The TD06H turbine mated to a larger compressor can deal with power levels nearing 550whp. I have seen a 2.0 dyno 611whp on a 75 shot using a TD06H turbine wheel in a 7cm housing.
I know that this is not a direct answer to your question, but hopefully it will provide some insight to what you can expect out of the turbo.
jeff
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
