Hi all, I have a brand new Wolf V500 ECU, loom etc. for sale.These ECU's are the bee knee's and aimed at entry level Motec equivalents, if they made them to suit the R34 it would have been fitted to my car but unfortunately AMS had other commitments and did not continue with the R34 project. The unit is 1 week old and comes with full warranty and receipts. I will ship Australia wise at buyers expense (or deliver in Melb metro) and am happy to answer any questions.
RRP is $1995 for the plugin units like this, $1895 for the universal
I'm asking $1500 delivered, that's almost $500 cheaper than you could buy new :laugh:
This unit is plug and play just like the Power FC but has many more features similar to the Motec M400
Info - http://wolfems.cart.net.au/details/696060.html
Review - http://www.productreview.com.au/showitem.php?item_id=6601
Welcome to the latest in high performance Engine Management, with class-leading performance and value.
Compact, powerful and with the latest features, the Wolf V500 offers 5th generation features through 14 years of research and development.
8 Smart, Full sequential Injector outputs, driving 1-32 injectors, including high flow, low impedance injectors down to 0.5ohms per output pin.
The V500 injector driver system reports live status of all injector channels including peak and hold reached times, injector current, short, weak and open circuits.
8 Full sequential Ignition outputs, driving 1-8 ignition coil packs in sequential, banked, single, rotary or inverted modes.
Latest 3D graphing, live dashboards and Datalogging software.
Advanced high-detail Fuel, Ignition and Control mapping systems, 2048 points at 125rpm steps with Easy Tuning modes.
Wide-Band Air-Fuel-Ratio (Lambda) system.
Dual Memory system, Power/Economy, Petrol/Gas modes and more.
Control Functions:
* 16 General Purpose Output (GPO) functions supporting Auxiliary Outputs, with windowed switching
* 6 MultiController Output (MCO) functions, supporting 3D and 2D multi-axis tables for mapped linear control of any extra outputs desired, including PWM, solenoid position and trim control of internal ECU parameters
* GPO and MCO functions can support VTEC/VVT, NOS, Water Spray, Stepper Motor, Emissions Control, Idle Up, Warning Lights, and any other additional devices required.
* Wide-Band Air-Fuel-Ratio (Lambda)
* Closed Loop Control
* Idle Speed Control
* Stepper Motor Control
* Turbo Boost/Wastegate Control
* Turbo Timer support
* Shift Light function, dedicated with up to 6 stages and flash point.
Dedicated Inputs:
* 13 Auxiliary Input pins available as many extra inputs
* Camshaft, Crankshaft, Reference and Sync Trigger inputs, Hall Effect, Reluctor and Optical, user selectable
* Internal MAP sensor up to 30psi boost (higher with external sensor)
* External MAP or MAF Sensor
* Throttle Position
* Engine Temperature
* Lambda/Oxygen Sensor, Dual Channel, Narrow Band or Wideband LSU4
* Air Conditioning Request
* Vehicle/Wheel Speed
Dedicated Outputs:
* 15 to 27 Auxiliary Output pins available as extra outputs (unused Injector and Ignition pins can be used)
* 8 Smart, Full sequential Injector outputs
* 8 Full sequential Ignition outputs
* Fuel Pump
* Thermo Fan
* Tacho Output
* Turbo Timer
Sensor Inputs have full OEM-style diagnostics and error checking on each input, detecting out of range or faulty sensors, correcting them to a safe value, and reporting the fault via a flash-code system. Any errors logged can then be inspected by the Wolf V500 PC Software included.
Security system preventing unauthorized engine starting.
* Requires connected Wolf Dash V500 for operation
Wolf Dash V500 support, connects to Wolf Dash V500 for on-dash monitoring and tuning.
* Runs engines up to 16 cylinders with full rotary engine support and odd cylinder counts allowed.
* Internal MAP sensor reads boost pressures up to 30psi.
* Supports most existing sensors in the vehicle, saving wiring and installation time.
* Latest 32 bit processor running at 40MHz with Dual Time Co-Processors, giving precise sequential delivery of fuel and ignition and supporting all other functions including high speed Datalogging with no performance loss.
* Weighs only 500 grams and measures 126mm x 114mm x 39mm.
Supplied with wiring harness, quick start guide and searchable installation manual.
The new Wolf V500 PC Software is included free with every V500 ECU:
Latest 3D graphing and ECU tuning procedures
ECU Datalogging with Variable Speed Playback
Unique Time-shifting function to save last 30 seconds of action before recording initiated!
Easy Setup knobs and sliders with instant live adjustments to a running ECU, see and feel your changes without delay.
Latest 2D graphing and sensor calibration options.
The kit contains:
1 x Wolf V500 ECU
1 x Wolf V500 Main Loom
1 x Wolf V500 Input Trigger Loom
1 x PC Software and Help File CD
1 x PC Serial Cable
1 x Set of ECU Mounting Brackets
1 x Warranty Card
2 x Wolf Sticker
No unfortunately not, they had my car for 1.5 months for development but had other large projects on with Subaru so it was put on the back burner. Apparently there's a need for a different interface board as the 34 has similar, but different electronics.
  • 3 weeks later...
  • 1 month later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
