I don't really like the new GTR!! I'd much prefer your's Ben, or a 34 GTR..just don't really like how it looks!
Don't get me wrong though. It is an awsome car and would be more than happy for it to live in my driveway!
Beach Volleyball--I'm in!
So, wednesday night at Elder st...is that right? what time? 6 or 7 I rekon it used to be (years ago) where on Elder st?
You missed out last night Fab! cruised everywhere..
haha, we were kickin around a foam ball, hacky sack style and this dude went ass up and as he landed head first his drink hit the ground and blew up straight in his face!!!! should have seen it man, funniest thing I've seen in ages.
hey, any of you guys cruise out to mt isa, quite a few skylines around here, i got a r33 impul pretty much stock atm apart from the exhaust and pod filter, got fmic and boost control on the way tho, if any of yas are ever out this way give us a yell. cheers dan
pass lol ill think about it if u will shout the fuel and running costs lol oi i read in the paper today al stainer the boss of the dragstrip. is complaining about hoons saying we need to grow up and get a life and to come out to drags and do it in a safe environment, and that paying the membership fees etc are cheaper than paying the fine. wich is all well and true but i reckon we should write a response to all the stuff being written about us giving us a bad name
Guest Rexlr8
Maybe if they wernt charging like a wounded bull for the strip things might change. As for hooning... Fri and sat nights... If we are lucky to leave the friggan car wash. Lee man, im with you on the respons. f**king over this shit im readin in the paper. Its funny, they'll send 3 f**king paddies to us at blathaskite or somewhere but when real things happen in town. Eg: young kids waiting at melankas, or walking the damn street causing trouble., they dont do shit... f**k ass town.
Sure drag strip is best thing since sliced bread for this town, but once a month do they really think they'll keep us of the street.
They point you boys out in the skyline. What about jess in that lancer, or all the other P-platers and shit. We have done up cars so its instantly our fault..
yeah, tis a bit far but a few guys are talking of going up to Darwin so you never know.
Last time I went through Isa i was wondering if the roads were made from tyre rubber there was so many burnouts!! lol :whistling:
Same goes Dan, if your in Alice. Catch up for a cruise..
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
