My friend was asking me if its possible for him to register a car in japan having bought it from auction here..
i couldnt for the life of me answer the question and id like to know as well..
I think ( read:think ) its possible for him.
any ideas or feedback?
thanks
https://www.sau.com.au/forums/topic/181903-question/
thanks
I think he should be able to... as the auctions are japanesse auctions like we have car auctions over here....
So the importers just buy them and put them in a container... their still registerable in japan
Edited by axe s
https://www.sau.com.au/forums/topic/181903-question/#findComment-3303376
thats helps a little but your not 100 % sure, right?
i wouldve thought the same about what you said..but for some reason i reckon if you buy a car from auction its slated for release from the country, not for re registering..i could be very wrong though..
can anyone give me a definitive answer?
https://www.sau.com.au/forums/topic/181903-question/#findComment-3303401
lol, no it's not. the majority of cars sold at japanese auctions stay on japanese roads... of course he can register it in japan, it's a japanese car. hell lots of the cars for sale at auction still have current rego which he would just need transferred into his name. the car is only 'slated for release' once it's been de-registered and booked on a vessel out. even then no one actually says "this car is for export only". it could come back and be registered again.
https://www.sau.com.au/forums/topic/181903-question/#findComment-3303416
mr new news comes through with the goods! :P Yeah i dunno why i was scratching my head so hard over it..common sense, Adam...common sense.
So he could go to the auctions with someone he knows and pick out a car, which could also have registration and pay the auction fees and cars costs and hes all hunky dorey? ill let him know. By the way, hes looking for an CLK merc or 5 series bmw.. should be able to pick one up very cheap compared to Oz the lucky bugger..RHD too..
https://www.sau.com.au/forums/topic/181903-question/#findComment-3303430
yep, he can buy a car at auction, pay for car and buyers fee, and if the car still has rego and shaken paid then he can transfer it when he picks the car up. if it has none then it's just whatever the usual rego process is (regardless of where car was bought from).
yeah the euros are pretty good value in japan.
https://www.sau.com.au/forums/topic/181903-question/#findComment-3303456
good news.
euros are great value richard. i saw a CLK going in auction and when the dust settled the thing was 3.2 mil. The car was a 2004 3.2 with only 20k on the clock..
i then checked car sales and comparative example were more than double that.. bit of a shock.
oh, by the way, failed finance...havent been at work long enough and neither has wifey... :P
never mind... Im just going to have to put more cash together.
https://www.sau.com.au/forums/topic/181903-question/#findComment-3303499
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
