Hey guys just wondering if i have a stock fuel pump in my gtr or not. I can hear it buzz loudly when i turn the car on (not start) for about 5-10 seconds. It's extremely noticable. Can you really hear the stock pump prepping? Thanks
Mine is quite loud as well. I think it is stock.
you are probably hearing the pump for the gearbox transfer case, that is a loud pump which turns on with ignition and goes for around 5-10 seconds.
The fuel pump will only do a 2-3 second prime on ignition to get pressure in the rail and can hardly hear it.
to make sure this is what you are hearing:
turn the ignition on
let the pumps do their thing until its stops pumping and no more noise
turn the ignition off
(and within 30 seconds i think it is?) then turn ignition back on
= the transfer case pump will not prime, but the fuel pump will.
^^ i hope that makes sense ^^ :P
Im pretty confident the fuel pump is the noisy one even when your talking about a stock item as mine does the same. Why would a transfer case pump be in operation at idle or with the ignition on only? They would only create pressure when you require front torque, thus locking up the clutch packs in the transfer case.
A better way to test which it actually is, is to remove the fuel pump fuse and switch the ignition on, make sure you havnt had the ignition on for quite awhile as mentioned so you would normally get the long prime noise.
I could hear mine; not _super_ loud though. The in-tank 044 I have now is only a shade if at all louder.
To tell if it's _really_ the fuel pump, pull the fuel-pump fuse and see if you still hear the noise
when you turn the key on.
Regards,
Saliya
Edited by saliya
sorry that's completely wrong. the loudest pump is the AWD pump. it primes when you switch the car on. there is an even easier way to test it. remove the AWD fuse, then turn ign on.
as for pump being standard or not, no one can tell you for sure just by the sound. sometime standard pumps get noisy. sometimes they are still quiet. sometimes aftermarket pumps are quiet, sometimes they are noisy. the only way to tell is pull it out and see what it is. or remove the fuel return and run it for a bit and see how much it puts out.
Fair enough. By the way, i didnt mean you could identify what pump you had by the noise i was just saying mine is stock and its noisy. I aggree with age they are likely to get louder. I also noticed my car does a quick prime if you leave the car idling for extended periods. Its the exact same noise that you hear when you first switch on the ignition but only for a real short time.
Can you explain to me how the transfer case works?
yeah, the second paragraph was not directed at you. just that it's impossible for us to tell what pump just because the guy says it's noisy when priming. if it's noisy when engine is running that may be another story.
as for the AWD pump priming at start up it's part of the systems check that happens when you turn a cars ign from off, to on. it checks sensors, abs circuits, primes fuel pump and primes AWD pump. and the AWD pump is by a long way the loudest. many a GTR owner have mistaken that noise for fuel pump noise.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
