  • Replies 90
Posted Images
Hot hot hot..! Mind if i ask where you purchased your TS GTR style front bar from? It's exactly what i'm after.
Thanks. Got it from GTautostyle http://www.newstylemotorsport.com/index2.php Call the number on their website and ask for Alan. A great guy he will deliver it to you personally if you are in Sydney.
looks cool where did you get the lip from on the first one and i also would like to know if you want to sell it.
That lip is an East bear part from Powerplay. Unfortunately its already been sold to another member of this forum. Most of you would probably have seen photos of his silver GTT :P
Nice TS front bar...time to get the CF bonnet & GT Wing to compliment together. Sure rocks as hell! Cheers!
Nuh leave out the wing, cleaner lines without them. Who needs a big wing anyway, not like ur gonna be travelling at 300km/h n need the downforce... and ur only asking for a yellow licky if u had one.
Would finish it off nicely if it had the front lip tho IMO, if only one was available for the Gt-t...
Nice photography btw Forged, good use of lighting.
Edited by G_Force
CF bonnet CHECK :sorcerer: probably could see it better if the you enlarge the last few pics.
Not fond of GT wings but I am considering a CF boot plus spoiler delete.
Cheers
2nd for sure, hot and very original. I was so impressed with your original GTR bonnet conversion that i did my own aswell. Found a perfect factory look bonnet seal which mates East Bear mole with GTR bonnet, let me know if you need some.
Nice 4 door mate. Can you pm me details of the bonnet seal?
Cheers
G Force, if you end up finding someone to customise a lip like this I'm definitely in for one :blink:
Where and how much was this lip?
If you were refering to the bonnet "lip" or mole as they call it. Its an East Bear item from Powerplay. Retails about $300 don't remember it exactly and they make a slightly different one to suit your Nissan aero kit.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
