hey guys did a search in the vic section and found threads about this for early 2006 nothing recent.
well i called up RE customs today and got quoted $800 to get the timing belt and water pump done. seems a little steep but what are you guys paying these days???
got quoted for a gates blue timing belts and all bearings and seals to be replaced and got told while the front end is out might as well to the water pump which is fine by me but $800 is a tad to high.
can anyone recomend me other places to try???
im in rowville SE suburbs and work in the city so any where close to the city or SE side is all good.
thanks
Ash
https://www.sau.com.au/forums/topic/182026-timing-belt-and-water-pump/
any decent mechanic can do this for you... but its isn't a quick job its a MAJOR service so I don't know if you will get any cheaper quotes... considering the parts will cost you almost $400 and it sounds like they are going to service your pulley bearings its not a bad deal
... small price to pay versus a timing belt or water pump failure... even a basic rebuild/freshen up will cost you over 4 grand
Yep would agree, a lot of parts used and labor also, sounds about spot on :P It's a major service, how many K's you at? Have you considered doing -
New Spark Plugs
New drive belts
New Oil Filter
New Fuel Filter
New Cam and crank seals - done with the idle bearings
Gearbox oil
Engine oil
Diff oil
Radiator and engine flush
Cleaning\replacing air filter
New Spark Plugs
New drive belts
New Oil Filter
New Fuel Filter
Gearbox oil
Engine oil
Diff oil
atm im on 103000ks
im only getting the timing belt and water pump done professional
the rest i can do my self which will be done in 2 weeks when the next service is due
New Spark Plugs- will do my self
New drive belts- what do u mean by drive belts??? what does this run
New Oil Filter-will do my self
New Fuel Filter- will do my self
New Cam and crank seals - done with the idle bearings- will be done with timing belt
Gearbox oil-will do my self
Engine oil- will do my self
Diff oil- will do my self
Radiator and engine flush- radiator already been flushed did it last week and engine will be done when oil is changed it 2 weeks
Cleaning\replacing air filter- done
You can do most yourself, but still doesn't change the fact everything has to come out to get to the Water Pump.
And then all the drive belts, idler/tension bearings etc.
All must be changed.
$800 is pretty reasonable for this in '07
im a mechanic an have done this to my car myself (no im not offering to do yours :rolleyes:...lol...)
I reckon $800 including a new water pump is a good price (your coolant flush was a bit of a waste when it'll all be drained out to change the water pump...but oh well), its about 4 hours labour for all of that so theres about $350-$400 there depending on labour rate itself. An parts would be about $400 as well id say
gates blue belts around $110-$130
tensioner & idler pulleys + new bolt around $130-$150
crank & cam seals around $30-$50
Water pump around $130-$150
few litres of coolant & bleeding up your cooling system around $50 - $70 (depends on what brand/type used)
so going on the higher side of my guesstamation.....theres $550 right there without the labour of changing it all, if they have a cheap labour rate of around the $350 for the 4 hours. Theres you $800 right there, which is a good price if you ask me, go with it.
hope thats of some help. Cheers
ash,
get RE to do the work. i know 800 is a bit more than u expected to pay but, if it saves u 4g for a rebuild, i think its worth it.
also ud hate for your car to go boom from over heating on the GOR cruise...lol
ash,
lol true
thanks guys
ye will be giving it to them to get the work done. juts wanted to get some opinions before i jumped for it.
spanks :D
but they said they were pretty booked for the next 2 weeks so will be taking it easy on the GOR
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
