is there a reset hole anywhere on the deck. my old kenwood cd player used to do that all the time, but was a quick fix. see if there is small hole the size of the tip off a ball point pen, use a bb pen and poke the hole - hey presto, out comes the cd. you will lose your programmed radio settings tho
https://www.sau.com.au/forums/topic/182059-cd-changer/#findComment-3306139
excellent, I'll give it a shot.
Furthermore, rather than start a new topic, because the car's imported the FM radio only goes up to 90.0
Any way to change this?
http://jaycar.com.au/productView.asp?ID=AR...=&SUBCATID=
https://www.sau.com.au/forums/topic/182059-cd-changer/#findComment-3307857
    • Wonder if JB Weld sponsored the event lol
    • There's a big difference between a car built with millions of dollars in R&D, and someone like yourself taking a normal sporty road car, and making it 5 times more powerful. At the same time, get a modern sports car, and you can turn them up towards the 1000hp mark a lot easier too. Also, give that Lambo another 20 odd runs, and chances are it too may break something.
    • There isn’t really a cheap upgrade here. If someone made a decent, bolt in 6 speed that holds some grunt, it would do very well. The 5 speeds suck. You can put a - OSG 5 speed gear set into it. Ratios are tall so it zaps the “zing” out of it. Had one, busted it. - PPG 5 speed gear set synchro or dog’s. Ratios are even taller. - An overpriced Getrag. Nice to drive, expensive to source now. - A sequential of some sort. Expensive, very expensive. How many times do you pop a 5 speed before you throw the toys out of the cot?
    • Yes, fair call. I don't have any special love for super/hyper cars but it was impressive to watch the Lambo line up against successive skylines without any problem at all.
    • Ok. What is the go to transmission upgrade that can handle some abuse with around 700nm at the hubs? Must be quiet gears as the car is being street used.
