Yeah my idea of fun .... about 30 young P-platers with powerful cars and no ****ing idea how to drive. Remember the last 4, 6 & Rotary cruise? I think there were 2 cars written off. I'd much rather cruise with people I know, and people that I know aren't going to do the wrong thing at the wrong time. (Nothing wrong with doing the wrong thing at the right time though :P )
There were only 2 cars written off this time....a VS went up the back of an Rx2 or RX3 very hard, which then smacked a BMW in front, not too bad damage for the Bimmer though. On Port Road we went past a Falcon that had severely clobbered a tree, looked very bad. Too many cops as well, except for Bunnings aka burnout central.
It wasn't actually that bad. Justice was serviced, though it was a bit sour. The VS that hit the R100, which inturn smacked the back of the beamer.. Anyways, the Beamer driver was the BIGGEST retard. In and out of traffic, serves him right for being a f*ckhead on the road!
Bunnings Mile End was good fun!!!
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
