i brought a rb26 for my calais before i went on a holiday and i spent over my budget and now i need cash so will be selling the rb26.
it came out of a friends 96mdl gtr and it still has alternator and all, car was on 36,XXX ks
comes complete with loom, inlet, injectors, rebuilt turbos with steel wheels not ceramic worth easy $1000 on their own, spark plugs coils. real clean engine no oil leaks nothing any test welcome it has %100 compression never boosted believe it or not.
im in melbourne coolaroo but can put it on a creat and if the buyer wants to organise freight, the companies will pick it up from my house if its on a creat.
the engines pretty dirty as its been sitting under the drive port for couple of months
asking $4500
nows its on ebay http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...E:IT&ih=013
call 0401267277
Edited by hiboostgtr
https://www.sau.com.au/forums/topic/182492-complete-rb26-with-boltons-and-loom/
"it came out of a friends 96mdl gtr and it still has alternator and all, car was on 36,XXX ks"
If the photos are of this engine, It IS a 32GTR engine, complete with 32 pwr steer pump and harmonic balancer..........
I'll start bidding at $1500
ill be honest, in the market for a gtr motor, and in the past ive burnt my self buying a dud engine, can you prove the compression is good, valve seals etc.? when was it last running? how many kms?
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
