Another full field of entries for Round 2 of the Toyo NSW Drift Series this Saturday at Oran Park.
Eugene Arendsen
Chris Easton
Jason Greenwood
Josh James
Chris Jones
Andrew MacGregor
Sam Pass
Brett Reid
J.J Screpis
Michael Truscott
Nathan Weissel
Anthony Bilic
Ben Ellis
Kirk Gyford
Ashley James
Brendon Keenan
Daniel Mackie
Stephen Pembrey
Matthew Salim
Tim Sorrasson
Igor Tunjic
Dion Yandle
Nathan D'Avoine
Scott Gibbs
Martin Jagodzki
Mitchell Jeffery
Mike Laverick
Marcus Newark
Matthew Porter
Alex Sciacca
William Thompson
Eiji Wakamatsu
https://www.sau.com.au/forums/topic/182672-toyo-nsw-drift-series-this-saturday/
damn.i would but have somthing else to go to allready.i was at the IDA track day last weekend though reprazenting on the hill watching from the car.it is allot better if you can just laze arround in the car and veiw.just like home :D
i seen dan makie out there and Fernando Wiehrl.there is some pretty good local talent out there as well.also quite a few crashes with pretty big damage.
hahaha great post Druncan :):D
Go Dan and Easto!
oh, Easto's entry's - fark me - MASSSSIVE!!
I was behind him going around OP North at Driftland and it was just amazing!
Yes true however when you go from an event like at Eastern Creek with a few thousand people, trade displays, car show, stunt riders etc to a dirt paddock at Oran Park Driftland it's quite disappointing from a spectators point of view.
