Hi guys just a couple of things lying around that i want to move.
RB26 Sump (no diff) $200
R32 Bilstein Shocks & Springs $600
New heavy duty Valve Springs(Suit step 1 cams) $300
Pair of M's Pods and elbows to fit them. $200
I have pics if you need em, shoot me a PM if you need more info,
Cheers
https://www.sau.com.au/forums/topic/182732-r32-gtr-bits-peices/
