We will be aiming to be there race ready with the new setup, hopefully making more power then before.
Everyone should come and see some backyard style race cars going hard at it for first place lol :)
So whose coming...competing or spectating?
Edited by r33_racer
  • 4 weeks later...
The only events i've been out to QR for have been the drift days, so i was just wondering if you're allowed to park round the fence of the racetrack, like on the drift days or if you have to park outside???
I'll either be taking out the 34 (if i can park round the track) or my bluey sss (NIZ013).
I'm hoping you should be able to park around the track, usually only the major events that requires you to leg it.
I'll be there, guess I'll bring the 31 out aswell.
Gasp! The phantom 31, that never leaves the carport...
Well lil bro, you could always bring my Rolla out??? I know how much you love it! lol.
Was a great day out there. Didn't see any skylines, apart from mine and lil bro's 31 cruising around. It only ended up costing us $10 entry fee.
A huge congratulations to our mate Richard in his "Pryme" VN for coming second in his category!!!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
