  • Replies 107
hrrrm
hills is just better than posing in city and bay dude
I couldnt agree more, but dont go thinking that cause you are in the hills is all good bud. At the end of the day dude if you want to drive your car to its limits perhaps you should start thinking in going to the track.
Me personally I dont do hills runs on the weekends cause its just plain stupid, way too many cops out there!
Cheers
Ric
omgwtf, as if you didnt pick up that that was 100% sarcasim.... sif meet @ bay then cruise to the city.. wtf?!?! mebe we could also do some fully sick burn outs while were at it...
oh and agree with richo, pushing your car to the limit = track, crusing and chatting with friends = SAU
and i recon we should change the meet point to our backup one from the other week... just seems safer imo
Yeah definately, cops like to frequent the original location.
Hi Mr Policeman if your reading this :D
ok i have pm every1 that has asked for one above.
im hoping the cops dont come to the meet point. if they do ummm yeh.
any idea's people? should i change the meet point and pm everyone?
sent.
should i have this main meet point then have another meet say like around 10pm but somewhere different?
could be like a quick re-group and get the other guys.
wher si the 2nd meeting point at around 10pm? if its near TTP or around that area, me sneezy n others may be able to join up.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
