R32 Rb25de Head, Q45 Afm, Blitz Turbo Timer, R33 Gtr Parts, Apexi Suspension, Updated 21/1/08 Prices Dropped!
  • Replies 59
Hey Mate have you still got the GTR Front mount. Can you send me a couple more pics and how much to post
it to Qld 4207. It looks fine is it in good nic.
r33 gtst rear bar still for sale, if so how much inc. postage to SA post code 5264
32 RB25DE head has no VVT-hence why i bought this one as it neglects any blocking off of VCT and is favorable for a RB30DOHC conversion into a 32.
33 RB25DE has VVT-if doing an RB30DOHC conv, requires welding of the heds vct oil feed. The head still requires oil to its vct, and you will need to tap into an oil gallery and run and oil feed to it. Most common fix is T ing into the oil pressure sender feed to aleviate this problem.
As above, thanks mate.
Cheers
vvt gives you more low end torque, it switches off after at a certain amount of revs
To get oil pressure to the VVT solenoid you need to run an external line from the oil pressure send hole in the RB30 block to a fitting on the RB25DE cylinder head. No machining of the block is required. On the cylinder head you just drill and tap a hole in the VVT oil gallery for a fitting that you screw the external oil line. So no machining of the cylinder head is required either.
Rear Quarter glass Left and Right hand side $50 each
And do you have the rubber surroundings for them
im also in sydney can you pm me or give me your number so i can give you a call
so in total $100 in total correct?
thanks
  • 1 year later...
hi john plz contact me on 0424558888 i am interested in some parts for gts-4 i will come to you as i am living at parramatta atm
let me know your details asap thx
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
