Ok guys, As the title states. Been workin on a mates car in his garage over the last couple of weeks. He has an RB25det sitting in his garage and it wasnt left sealed. Anyway, his old man decided to get the angle grinder out and cut a number of aliminium pipes for something he's making. When going to start a days work on the car the other day, we noticed the engine had a layer of fine aliminium dust over it. In panic we got the vaccum cleaner out and sucked up what we could of the filings. We removed the rocker covers and vaccumed the cams around the areas below the breather holes on the rocker covers, then put the vaccum up against each exhaust and intake port...
Experienced answers are needed here.
Is this engine worthy of going through all the work of a drop in even if there may be a little bit of aliminium left around that we could have missed?
Or is it now destined to be rebuilt?
Get a torch and look for any shiny bits inside the ports or anywhere inside the motor.
My experience with an old 250 ford motor when I was 16 (I did a similar thing) has been a vac cleaner does very little to suck anything out of the ports unless a valve is open where it is able to create a little turbulence that picks the metal up.
Good luck.
if you think there could be dust in some cylinders you're best taking the head off turning the engine upside down on the stand and washing out the cylinders with carby cleaner.
if there's only a small amount of dust that got inside the cam cover you should take the covers off, go somewhere relativley clean out of wind.
put the head on a couple of bits of wood to space it off the bench with the cams facing down, then it's a matter of dowsing around the cams and buckets with carby cleaner to wash any dust out that might be there.
you'd want at least two cans of carby cleaner if your going to give it a good wash out.
Agreed
You'll kick yourself later if you find there was something
read post 3 of this thread
http://www.skylinesaustralia.com/forums/in...howtopic=183511
the filings will sit on the top compression ring between the piston crown and the bore. The filings will glaze the bore and not allow the ring to seal properly causing blow-by.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
