Hey guys..
Just got back in my car after its been parked for about 3 hours and had fluid all over the ground.. Id say about as much as a gatorade bottle spilled over the ground..
It seems to be comming from the aircon area, just under the front cabin, however the aircon is off? everytime the car is running it starts to pump out massive amounts of it.. and then slowly seeps out when its stopped.
the fluid is yellowish (like orange juice) in color and slightly oily.. its similar to water so Im assuming it must be the aircon however it has not been on for a fair while.. not since sunday??
I checked all the other fluids and they are at maximum level, it does look similar to radiator fluid and smell similar but the fluid in the radiator is not dropping. The radiator fluid is also orange/brown :S
Should i take it easy and assume its the aircon? never happened before so perhaps the aircon has been blocked?
if anyone could help would be great...
Thanks
Yeah it cools..
The coolant is japanese coolant.. Shipped from japan its red/brown and fades with time.. its only got 8000km on it.
Any way to check the refrigerant?
It slightly smells like coolant, and is slightly oilly.. so im confused why its not the full on smell.. its just very faint..
The fluid is overfilled by the mechanic .. so could it be overflow? why its over flowing now i wouldnt know
Yeah it cools..
Is the car an auto? If it is check your radiator overflow bottle does not have oil sitting on the top. The autos pass their gearbox oil through the bottom tank of the radiator for cooling. If a leak forms inside the tank you will get oil in your water which is likely to spill out into your overflow bottle. Be very afraid!
Its coolant and one of the pipes has let lose.. seems the clamp may have come undone.. lets hope i dont need to replace the silicone piping..
Unfortunately have to drive home.. Now I no I should have got roadside assistance..
Lets just hope I dont run into any problems.. Ill try seal the join with gum or something for a temp fix .. lets hope it works for the time being
The silicone tubes are located here behind the engine.. anyone know where to find a replacement?
Edited by DECIM8
This is screwed! There was a hole in my pipe which runs off the engine, yes the metal pipe .. about 1-2mm diameter.. I dont know if this part is replaceable..
For the mean time (how its prob been running since i bought it) we cut the hose end off and pushed and clamped over the hole, its holding and I have presure back in the radiator again thankfully.
Anyone got a solution which doesnt involve removing the engine to hot weld it? Anyone got any idea wtf the part is?
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
