R32 GTR for SALE
Summary – Extremely clean and well maintained GTR. Extensive modifications professionally completed in Australia. 339rwkw @ 18psi on Toda Racing dyno, 268awkw @ 13psi on CRD dyno. Highly modifided including: Rebuilt engine with forged internals, HKS 2540 Turbos, Trust intercooler, HKS exhaust, Oil cooler and remote filter, Coilover suspension. See below for full details.
Extremely clean, straight and well maintained R32 GTR – very rare to find an R32 in this condition.
Selling as we now have a little baby girl and so decided to sell a couple of my cars.
This car is complete and ready to be enjoyed and appreciated by a new owner.
Over $75,000 invested in modifying and updating the car over the last few years.
Colour: GunMetal Grey
Year: 10/1992 (Low Volume Compliance in 2001)
KM’s: 69,814
Registered (NSW) until Oct 07
All modifications professionally completed in Australia
Over 30 pages of receipts
339rwkw @ 18psi on Toda Racing Dyno
268awkw @ 13psi on CRD (Croydon Racing Developments) Dyno
Engine:
Full rebuild completed around 12,00km’s ago
Wiseco Forged Pistons, Pins and Rings
Honed, Closed and Aligned Conrods
Balanced Conrods and Pistons
ARP bolts
Chemically cleaned
Bored & Honed Block
N1 Oil Pump
N1 Water Pump
HKS metal head gasket
SUMP baffle
HKS 2540 turbos – installed new when engine rebuilt
Custom turbo dump pipes
HKS Stage 2 cams
HKS adjustable cam gears
600cc fuel injectors
Trust 5” Intercooler
K&N Air Filters
Microtech LT-12 ECU – maintains factory connector and loom
Microtech Digi Handset display/controller
AFM’s removed (uses MAP on Microtech ECU)
Blue painted cam and timing belt cover
Plenum polished and painted clear
Polished Turbo intake piping
Remote Oil Filter relocation kit – USA made
Oil Cooler (large) mounted behind side bumper vents
Braided lines for Oil cooler and remote filter
Oil Catch can and breather with braided-look piping
Power Steering cooler
New Alternator
Heavy Duty Ceramic Button Clutch
Exhaust:
HKS full 4” exhaust system
HKS Super Dragger rear muffler with 5” tip
Hi-Flow Catalytic converter
Fuel system:
Bosch 044 external fuel pump in boot
Bosch 044 in tank pump feeds surge tank
Surge tank in boot (fitted to side so boot is still useable)
Custom Dual feed fuel rail
Braided Fuel lines with competition fuel filters
Malpassi fuel regulator with pressure gauge
Custom fuel lines from boot to engine
Battery relocated to boot with custom wiring in engine bay
Suspension:
JIC Coilovers with height and dampening adjustability
Spare set of Soft springs (Firm springs currently installed)
Front bushes replaced
NISMO front strut brace with Blue paint to match engine
ARC rear strut brace
Brakes:
Brake Callipers painted gold
Cross Drilled rotors front and rear
Ferodo Brake pads
Brake fluid Motul RBF600
Cooling system:
40mm Aluminium Radiator
Silicon (blue) radiator hoses
Twin Thermo Fans
Thermo Fan controller - adjustable
New Thermostat
Interior:
Greddy Profec boost controller with display
Greddy Oil temp and Oil pressure gauges in pillar mount
Mines Boost gauge (replaces stock gauge)
MP3 head unit with CD, USB and Memory Card inputs
6.5” splits in front doors
6” rear subwoofer speakers
Momo Steering wheel – standard factory wheel also available
Polished steel Gearknob
Dash in excellent condition (no lifting, a few very small holes)
Front seats in great condition (no tears just some normal wear)
Rear seats in excellent condition (one very small hole)
Carpet in excellent condition
Original GTR floor mats
Exterior:
Sparco Racing Viper 17x9” wheels
265/40/17 tyres ~60-70% tread
Lightweight fibreglass front bumper
Lightweight fibreglass bonnet with cooling vent over radiator area
NISMO side skirts
Rear spoiler removed, holes filled and boot repainted
(Factory rear spoiler available as spare)
Paint is in extremely good condition
Rubbers and trims all in great condition
No evidence of accident damage anywhere on car
Alarm/Security:
Alarm (High End) - Shock Sensors, Twin sirens
3-point passive immobiliser
Central locking
Servicing:
All fluids replaced in last 6 months
(Engine, Gearbox, Diffs F & R, Transfer case, Brake, Coolant flush)
Engine Oil/Filter changed very regularly since rebuild
Turbos inspected in last 3 months and reported to be in excellent condition
Compression test done in last 3 months showing correct & consistent pressure across all cylinders
Issues
- Passenger door central locking actuator stopped working reliably
- Minor play in rear Hicas
Asking price $34,500
For more details please contact Geoff on 0413 488 688 or [email protected]
PHOTOS
post-23126-1188964524_thumb.jpgpost-23126-1188964541_thumb.jpgpost-23126-1188964564_thumb.jpgpost-23126-1188964800_thumb.jpgpost-23126-1188964812_thumb.jpgpost-23126-1188964755_thumb.jpgpost-23126-1188964843_thumb.jpgpost-23126-1188964833_thumb.jpgpost-23126-1188964741_thumb.jpgpost-23126-1188964856_thumb.jpgpost-23126-1188964780_thumb.jpg
Edited by geoffw
this is heaps funny cause my car is the same colour with the same exact rims, i havent seen them on anything else before, they sparco rims???
good luck with sale, you can buy mine when you sell it :domokun:
good luck with sale, you can buy mine when you sell it :)
Thanks. Yes, they're Sparco rims. They are specific for a GTR, but I've only ever seen them on one before - maybe yours.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
