Hi All
I have an RB25 plenum chamber 4 sale, I bought it off ebay for $350 + postage.
Reason 4 selling is that i have an Rb20 and was told it would work, when i went to fit it i found out that i need RB25 injectors and fuel rail. Seeing how i just spent a grand on injectors i chose to leave it the way it is and save up 4 a custom plenum.
$250 firm
Also 4 sale is a 93' R32 power steering pump. Was working great, reason 4 selling is that i upgraded 2 a Rb25 one, because I no longer have an off the lines 4 the rear steering.
$60 ono just jap sell them 4 $130
Also i have a stock rb20 intercooler. plus most of the piping. A R32 parcel shelf and a stock airbox. Not 4 sale will give away, just wasnt sure if there was someone out there that needed one and i didnt want to just throw them away.
I live in the southern highlands but for that little extra I am willing 2 drive to sydney as long as money is guaranteed
Thank you, either email me at [email protected] or PM on here.
Edited by PetieR32
https://www.sau.com.au/forums/topic/183854-rb-stuff-4-sale/
Hey all
sorry tried to put a pic up but couldnt get it to work, its a trust or greddy copy, cant remember which one.! everyone says different lol. GTR style. can email a pic if wanted.
Thanks
Edited by PetieR32
https://www.sau.com.au/forums/topic/183854-rb-stuff-4-sale/#findComment-3332243
Hey mate,
Is this a front style like this
http://www.thor-racing.co.uk/images/rb25_plenum_mod.jpg
of is the the standard rb25 where u have 6 cyl and the throttle body is in the middle of 3 and 4 cyl?
Please let me know 0401651346, i will get it off you if its as per pic
Hey all
sorry tried to put a pic up but couldnt get it to work, its a trust or greddy copy, cant remember which one.! everyone says different lol. GTR style. can email a pic i wanted.
Thanks
https://www.sau.com.au/forums/topic/183854-rb-stuff-4-sale/#findComment-3333296
Hey mate
nope its just the plenum. i think u just use all the stuff of a standard one. Dont hold me to it but. sorry
stole this from a site that sells them,
Intake manifold
High Flow, High Performance, Race Intake Manifold
Made of cast aluminum
Super High Flow , Large Runner, Large Plenum Performance Intake Manifold
IMPROVES HIGH END POWER Especially at high RPM!!!
Especially with performance cams and Big Bore Throttle Body!!!
Pre-bored to accept Large Throttlle Bodies
https://www.sau.com.au/forums/topic/183854-rb-stuff-4-sale/#findComment-3344525
You need a q45 throttle body, or an adapter plate which sells for $120.
How does the casting look between the water gallery and the ports, these manifolds are a bit hit and miss, some are thin, others seen to be ok, but they all need to be milled on the head surface, as the casting is too rough to seal properly.
https://www.sau.com.au/forums/topic/183854-rb-stuff-4-sale/#findComment-3344887
Oh yeah forgot about the tb, but bigger tb is always better he he, not sure about the water thingy, i'll have a look and get back to you.
But thats y its going for $350 or something
Thanks
https://www.sau.com.au/forums/topic/183854-rb-stuff-4-sale/#findComment-3349576
  • 4 weeks later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
