SAUWA MEMBERS ONLY CRUISE
This will be a Country Cruise with plenty of time to socialise at meet spots.
This is Strictly members only, and details can be found in the members only section.
If your not currently a member and want to join up then click on the link below.
SAUWA Membership Form
When: Sunday 30th of September
Please no whoring of this thread. On topic discussions only. Other posts with be removed
Would be nice to see a huge turn out of SAUWA members for the cruise
Paul
SAUWA President
https://www.sau.com.au/forums/topic/183905-sauwa-members-only-cruise/
New members if you have sent your membership forms in and have paid. Please pm me with the payment details and I'll add you to the members area asap.
Hey Dan, i submitted the member form but it did not request payment?
i want to pay via internet banking. can i do that?
How do you then access the members only section so i can find out location of the cruise on the 30th?
thanks
sam
recently come over here from sa for a few months, will have to sign up and meet some like minded driving enthusiasts. Anyone want to take me for a ride on this cruise coming up (I dont really want to take a hire car -- shitty xr6).
