If thats the case i guess brocky must have been a real tryhard. :nyaanyaa:
... please u knw what i mean.. just proving ur own ignorance.. look like a wanker anymore riceboy..?
AWD + Water = funny shite, last night was interesting, i proved your theory wrong Noel :) they do get sideways
yes they do.. tried a 6000rpm launch in the wet in one of them yet..!!! i remember doin that once.. scared the shit out of my mate following..
https://www.sau.com.au/forums/topic/183906-hey-hey/page/2/#findComment-3333464
bahaha you have the SR wont you break a rocker arm before too long :)
jk
thats funny.. his SR is stronger than ur RB20 its closer to being a GTR than a GTST really.. Solid lifters. 87mm pistons bigger oil pump similar to a N1.. the GTiR engine was the GTR or SR..
and a set of RAS will fix that.. i fitted some yesterday on a VCT SR.. stupid having to angle grind the rocker cover to miss the VCT gear oil shield.
https://www.sau.com.au/forums/topic/183906-hey-hey/page/2/#findComment-3334947
Ok, well seeing as im welcome here, heres some pics for those of you that havent seen it in the flesh, or should i say metal, or plastic, what ever it wants to be!
The AVC-R is now on the dash where I can get to it easier, and the coffee stain on the drivers seat is gone haha
Edited by KnoTT
https://www.sau.com.au/forums/topic/183906-hey-hey/page/2/#findComment-3335130
    • I had a 1981 ALFA with an electronic speedo sender that would work for months at a time, and also noth work for months at a time.
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
