  • Replies 187
Posted Images
Just got back from the workshop. Trouble looming. Council tied up his afyternoon sprouting by laws and regs re noise (I told yall it was farkin loud)
just about done all the low and midrange tuning, I have never seen anybody so meticulous. Hes dropping the car off shortly, then It goes back monday when the animal will be unleashed. Very sedate 300rwhp at 8lb atm. Found an extra 50 hp just playing with the inlet cam. The idle sounds off the planet. Mick asked me if i wanted it smoother as he would alter thye cams to suit, i told him if he touched it i would kill him, twice, it sounds farkin haaaaaawwwwwwt!!!!
For those wondering why this is taking as long as it is its really simple. When i questioned the magic man re the time frame he told me straight up. If you want a tune like 90% of tunes going around atm then fine, I'll do it and you can have the car in a couple of hours. But what you will get for your money is a large hp number and a car rich as all shit to keep it safe, If you want the tune to unlock the potential of the build then Farkorf and let me tune it in my own way and my own time....I farked orf. :)
I understand the time required for a decent tune, but wow. Is Mick working on your car in between other jobs or just taking a farking long time on yours alone. I'd be scared to see your bill for the tune....you'd want some serious power/response!
the thing now pulls harder with the current 300hp than it did with the previous 340hp on the run in tune. and oh my son of rajab, that camy lumpy idle is just sooooooo porn :ninja:
rofl, I'm with you Matt. If he was seriously spending all that time on mine alone i would want a veyron at the end of it.
Due to illness and some other issues he has only spent 3/4 hours on mine. Patience grasshopper, it will be worth the wait.
man i am so unlucky i was at ipswitch like 1 -2 hrs ago...and i missed yah...bugger.
sounds like it is going to haul arse on 1 bar...cant wait to see it on 1.5 bar.....mmmmmm..
noel's busy as a mofo so i'll update you guys
it aint making anymore power than 440bhp, dont matter what boost, 18psi, or even 23psi. we think the cats collapsed.
also its now not holding boost, it's spiking. but i believe thats because the exhaust gases rnt escaping quick enough (collapsed cat) and the gases are backing up against the wastegate, forcing it closed and then increasing the boost.
he's also had to change fuel rail (got my tomei rail on there now) because the injectors werent sealing to the rail and had to change boost controller (now running blitz spec s) as it wouldnt allow any adjustment over the 9psi wastegate spring
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
