  • Replies 57
Hey fellas i rang brant up and they told me that none of their alarms work in tandem with ANY turbo timers..
is this true? or has the guy bullshytted me??
ive got aHKS type 1..
also ppl that i spoken to..said that using a turbo timer..u gotta see how much the engine "shudders" when the timer turns off the car...cuz the engine shudder can cuase the "armed alarm" to be triggered and go off...
just a though
mc
:shake:
https://www.sau.com.au/forums/topic/1840-brant/page/2/#findComment-36266
Err~!! take out my TT?? i havent even put it in yet..hehe
yeah prank the type1 has a 0-400 etc etc..but you wont be able to use the TT function..
DOes anyone know of any INSURANCE APPROVED alarms on the market that support turbo timer functions? for say :
under $600
2point immonbilisation.
black wiring
separate brain and siren?
pls help
mc:shake:
https://www.sau.com.au/forums/topic/1840-brant/page/2/#findComment-36309
Originally posted by soopamarcus
WTF? are u kidding me? the tech guy at brant said they couldnt get it to work with and TT...
what turbo timer does ur friend have? and also which model brant does he have fitted?!~
mc:shake:
not sure - i think its an older model brant system...
i'll find out, but i know him well and i have seen it all work.
https://www.sau.com.au/forums/topic/1840-brant/page/2/#findComment-36345
I got a TT and a Brant.
The deal is for some legal reason turbo timmers ain't legal so brant doesn't want anything to do with em.
What my car does is
You can look the doors and let the turbo timmer run then 30sec after the car turns off the imobiliser turns on but the alarm will not turn on unless you hit the button agian.
So it sorta works...
https://www.sau.com.au/forums/topic/1840-brant/page/2/#findComment-36437
The Brant AA02 and Nemesis both work with turbo timers as I know a two people on this forum with this setup working fine.
Turbo timers are illegal though and if your insurance company finds you have one i have heaard they may not payout if your car gets flogged. Dunno how they can do this though....
https://www.sau.com.au/forums/topic/1840-brant/page/2/#findComment-36503
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
