Im sorta pissd off at the moment. Just broke one of my cv shafts for the 3rd time. I did an r200 conversion a while back and have had the worst luck with having, GOOD STRONG, half shafts made up. I never got the original ones with the diff and have had to get them made up every time. Can anyone please point me in the right direction for strength and reliability. I want to make this the last time i do them so i want to do them properly. Im close to just going all out on a 9in conversion. Im only pushing 245rwhp :whistling:
Cheers.
https://www.sau.com.au/forums/topic/184113-drive-shafts-half-shafts-cv-shafts/
As above!! What type of shafts are they being copied from?
I've never broken one, the only person i've ever heard of breaking one was in a dr30 with near on 300rwkw, and he shattered a cv joint due to old age more then anything!!!
If you want a good OE replacement half shaft, get the R31 import half shafts, but you need the stub axle and everything, and they are meant to bolt straight up (both DR30's and import R31's had the long nose R200 LSD)
ill get some pics up and try to explain everything in detail. The first two broke the shaft on the wheel side and this last one has been snapped on the diff side. Very frustrating. But ill get some pics up to help explain the situation a bit better. Cheers guys.
ok, so this is where i am at.
I purchased one of these diffs, just not this exact one. Mine looked like this and came with chopped half shafts.
As you can see they are not complete shafts so i went to a cv guy and he said just give him measurements from diff to stub axle and he will make up shafts to suit. So i did this. First two shafts broke after 5 min.
And now the last set look like this after he chopped my output shafts down and welded on honda cv joints which he said will fix the problem.
Now these have lasted for about 9 months or so, but after a night at calder on friday i managed to break this one too.
This is how i mounted the diff with the nismo housing. I used the original moustache bar and welded on a bar vertically to suit the up and down bolt pattern.
Now im pretty sure that all r200 diff housings are going to have the dimensions.
What do i do now?? I just need proper shafts and im sure i shouldnt have this problem anymore, but sourcing them is not gonna be easy im guessin..
Ah, I see. You are using the longnose R200 with the viscous LSD centre. That would be why you needed to get axles made up. The viscous centre needs that axle with the long output shaft (ie. the one that broke) to work properly. The other one is just a regular old R200 longnose shaft.
Now, if you want "real" halfshafts, I would be speaking to the nice gents at Datsport about them. See if they can get you some, particularly if you want to keep the viscous centre.
If you want to use regular halfshafts (available from a Z31 300ZX at your local wrecker, but getting harder to find), you will need to change the diff centre, either to an open centre, or to a plate LSD item (I went for a KAAZ).
I don't know what/how they made your axles, but that break looks like it is easily replaceable. Did you say it is a Honda item? It is a shame that you didn't get a set of original axles at the beginning. It would have been a straightforward job for a driveshaft shop to have put the viscous output shaft onto the other (say, 300ZX) axle. If I was you (and wanted to keep the viscous), get the driveshaft shop to mate that long output shaft to a 300ZX halfshaft and all will (should?) be sweet. Then use the other 300ZX shaft on the other side too.
My 2.2 cents (GST inc.)
z31 shafts seem to be the way to go. Ill have to try and hunt some down. I dont mind what type of centre i use. I only got this one coz it was the cheapest r200 lsd diff i could find at $290. Everywhere else was asking upwards of $800.
And it would have been ideal that i got the complete shafs, im guessing i would have never had this problem! oh well, nothing is impossible. Thanks for the coin!
how much should i be paying for z31 half shafts and also what is a good CLSD worth?
That's a good question. I bought a pair of half shafts for $80 each ($160 for the pair) from a wrecker in south Sydney about 12 months ago. Sorry, I can't remember the name. I thought that was a rip-off at the time, but paid it anyway.
LSDs are a different kettle of fish. As I said before, I put a KAAZ LSD in mine, which I bought from RMS Motor Parts (site sponsor) for just over $1K about 12 months ago. Basically, any plate LSD that will fit into a short-nose R200 (like the Silvias and R32 onwards use) will fit the long nose R200. What you have to watch out for is the size of the bolts that hold the crownwheel onto the centre. The early long nose R200 had 10mm bolt holes, the late ones had 12mm holes. All short nose R200s have 12mm holes. Therefore, if you have an early long nose R200, you need to sleeve the bolt holes to mount the crownwheel.
I am led to believe that the viscous unit that you have uses the 12mm bolt holes, so changing to a new centre is easier.
Another option that may be worth considering is getting some shafts and flanges from a Silvia / Skyline and adapting them? I don't know how keen you are on getting Frankenstein shafts again...
Im happy to pay up to $100 each MAX but cheaper is always ideal.
Im looking at doing something similar to THIS
From what ive read its the strongest i will ever be able to get the shaft and cv joins without having to use a billet shaft.
So if i can get some z31 turbo shafts im half way there.
I have read somewhere that my crownwheel bolts are 12mm, so thats something positive, and with all r200 housings being pretty much identical that all centres are interchangeable (gotta love the nissans). So im looking at roughly or there abouts $1k for a centre? I hope it outlasts my need for racing!
I have given thought to using silvia or skyline shafts but dont really want to be experimenting again. Im looking to do something that someone has already done sorta thing. If it wasnt my daily driver then i would take more time and look further into it but i need the car back on the road quick smart!!
What centre would i be looking at getting? A 1.0 way 1.5 or 2.0?
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
