Hey Guys and Girls
just bought a GTR front bar for my gts-t it has already been set up for my car but need to paint it i could just send it to a panel beaters and get them to do it but most of them are pretty dodgy and i have access to painting gear just wondering where i could buy paint from??? im SOR but dont mind going north im thinking that ill get two pac but i was told that you need a who bunch of safety gear to spray it on is this true??
Cheers
Matt
https://www.sau.com.au/forums/topic/184404-paint-shops/
Precision Panel & Paint
-High quality resprays
-Body/rust repair
52 Raymond Ave, Bayswater
Ph: 9271 5311
Dalcos Panel & Paint
-Body work & resprays. Also provide a mobile service, contact mobile number
33 Adrian St, Welshpool
Ph: 9470 6577
Mb: 0408 470 657
https://www.sau.com.au/forums/topic/184404-paint-shops/#findComment-3338526
-Body/rust repair
Ph: 9271 5311
Ph: 9470 6577
Mb: 0408 470 657
Cheers Topaz your a champ :D
https://www.sau.com.au/forums/topic/184404-paint-shops/#findComment-3338669
drop it off to me, i will paint it, assured smash repairs, ask for MEL, not all panel beaters are doggy,
9455 4499,,,,,,,mel,
I just got off the phone to HRH MEL, easy going guy. I'm just in the mids't of trying to find a panel beating shop for a "full" Bare metal respray. I'm dealing with Mel atm to see what solution we can come up with.
Watch this space:) if all goes well, will post progress pics and final product.
cheers
rob
https://www.sau.com.au/forums/topic/184404-paint-shops/#findComment-3341805
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
