^ lol
I actually dont have inner guards on one side, after a minor mishap with the sand trap, ripping my front lip, plastic guard thingy underneath the engine bay and one side of my inner guard out.
The inner guard doesnt really concern me, just more of the plastic piece that stops sand and stuff from going into the engine bay. Its hard to find that piece and I was thinking maybe just get a diffuser which should work just as well :)
please elaborate on inner guards = defect?
as i never thought it would be.
I cut out the top part of the inner guard, leaving the sides still in place, cable tied the wires, and insulated some wires/holes.
How would a cop notice no inner guards if the car is lowered?
By tilting their head I guess. I guess what hes trying to say is its just another thing that cops may pick on. But so is almost everything else you do to your car ;)
Btw, if anyone decides to remove their inner fender guards after reading this thread, i'll be happy to take them off your hands :)
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
