For Sale
Series 1 dash panel.
The bit that goes around the stereo, air con vents and over the top of the steering wheel.
Needs painting
$100.00
Series 1 gear surround.
The bit that goes around manual gearstick and meets up with the above part.
Needs painting
$50.00
Series 1 drivers side switch panel.
The bit that sits in the drivers side door and holds the switches (does not include switches)
Needs painting
$50.00
Get yourself a whole other set, paint them a colour of your liking and swap them in and out as you please.
Will sell the above 3 pieces as set for $150.00
Series 1 bonnet grill
The bit ... you know where it goes..
$50.00
https://www.sau.com.au/forums/topic/184527-series-1-grill-make-an-offer/
  • 3 weeks later...
  • 8 months later...
  • 4 weeks later...
  • 6 months later...
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
