  • Replies 50
Hi Mike , welcome to SAU SA .
Another mike with a R32GTR , double trouble :D
Might see you around.
definately will, i will be heading out on that cruise on the 30th so hopefully i'll get to meet most of you guys and put faces to user names :D
  • 2 years later...
Hey my name is chris and i am am finally a member of skyline australia. I have owned my skyline for about 4 years now and have enjoyed every bit of it.
I look forward to conversing with everyone.
coolness, welcome. please familiarise yrself with the forum rules, and enjoy sau
-D
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
