SAFC 1, Turbotech manual boost controller and Rockford fosgate P1 12inch sub up for sale.
$180 for SAFC
$20 for boost controller
$100 for sub
The boost controller and sub available. SAFC its UP FOR SALES AGAIN PRICE REDUCED FOR QUICK SALES BARGAIN!!!!
the Rockford fosgate P1 12inch sub is very very good condition. i took it out from my old sub box. i had 2 12inches but i took one out to have some more space on my R34 GTT
it is very good condition as new. I paid 900 for two subs when i bought them.
i dont have pics of sub now ill post picture later on
please pm me any interest!
the price is nego-able and i can post them interstate at buyers expenses.
thanks!
paul
Edited by tyaos
hey dude,
where about in Sydney are you?
i am from liverpool area.
I will take the boost T plase.
can do pick up if you are not far.
cheers,
RBFIRE
the guy sent msg before you didnt want it because city is to far
you can pick them up in city today if you see this msg today
or call me on 0431 715 991
cheers
paul
Edited by tyaos
I would go the SAFC, but isnt a new SAFCII only $350? If u want $180 for a second hand lesser model, is it worth it? :P
I would go the SAFC, but isnt a new SAFCII only $350? If u want $180 for a second hand lesser model, is it worth it? :laugh:
As far as i know the SAFC 1 still selling over 200 on ebay (second hand) look on this web
http://cgi.ebay.com.au/APEXI-S-AFC-SAFC-SI...1QQcmdZViewItem
thats why i put up 250 ar first place and priced down for faster selling
if you still want it please call me on 0431 715 991
cheers
paul
Edited by tyaos
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
