well i just got a quote 200 for rear pods painted and fitted and 220 for a front lip painted and fitted and that was with the sticker discount..
Hey what font lip is that? got any pictures :thumbsup:
https://www.sau.com.au/forums/topic/184917-bodykit/page/2/#findComment-3361009
yeh thats a good price, as autoworx sells the lip for $280 by itself, not fitted or painted
might head down there this weekend too
when it comes to body kits and panel and paint you get what you pay for
I could get bodykits in for 600$ for a full kit and I know painters who would paint them for peanuts
but I dont want people harassing me 12 months down the line
https://www.sau.com.au/forums/topic/184917-bodykit/page/2/#findComment-3361248
isn't that a really good price?
Cheers
Chi
well i just got another quote that was 20$ more but this was for spoiler front lip and pods not just front lip and pods off a person i have used before that did a great job so they really arent that amazing :D and the price he provided was with a sticker on :thumbsup:
https://www.sau.com.au/forums/topic/184917-bodykit/page/2/#findComment-3361484
$600 + a few peanuts sounds like a good deal for a full kit! hook me up! :sorcerer:
https://www.sau.com.au/forums/topic/184917-bodykit/page/2/#findComment-3362127
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
