hey guys,
just want to know whether anyone has had expirience with these plug in retuned ecu's from japan? i got my hands on one from a mate cause he thought i might want it....LOL (why not)...
just wondering....has anyone used one? results? doesnt matter what rb motor....but i just wanna see if they r really a sham..coz atm i got std ecu with fuel cut defender running the mods i got listed below.
is there a website to check the computer ID number or watever u call it? cheers. i got another ecu planned for my 32....but maybe this could be good.
my mods:
full 3 inch X-force exhaust
hybrid frount cooler
highflow r25 turbo
fuel pressure reg
what gains r there from these ecu's? sorry guys im new to the ecu side of cars.
cheers,
daniel
https://www.sau.com.au/forums/topic/185058-blitz-access-pre-tuned-ecu/
The only gain is a sketchy tune state.
I say this because the tune isnt for our fuel, and you have no idea what mods the ECU was tuned for to begin with.
Japs ECU's like that unless re-tuned here (sometimes impossible), really are mostly useless unfortunately, and can cause far more harm than good to your motor.
i had one, put it in my 32, was no different then the standard one at first, but after a couple of weeks using it i started to notice i had slightly better fuel economy and no speed limit and rev limit lol.
but as r31nismoid said, they can do more harm then good, because you dont know what it was originally tuned for.
mines been running in my car now for over 1yr, only cause i havnt gotten around to takeing it out lol.
i have had good success with Mines ECU's
But like what most pple say they are not tuned for your fuel.
Most ones iv got from Japan have been for stock injectors and are just a general power up like what your would get for your Civic from "Chip Torque".
But with that said most Mines ecu's i have used have given better ecnomy and a little bit harder on bout 14psi with only basic mods to an rb20.
I have one mines ecu for a a31 that came with GTR injectors,GTR Pump etc etc and it was a diaster, on 8psi the thing would ping its ass off.
Although tuned roms are still popular in Japan, i would only buy one hear if i new what it was tuned for.
Blitz access expreriance is only of an sr20det 180sx. Thing went really well for what it was.
Cooler, stock turbs and had seemed to go realyl well with the ecu in it.
Then one day it just died. :wub:
Throw the ecu in, and just take it easy, listen for pinging!
Make sure you have a good tank of premium and just take it easy until you know it will run the car fine.
Gooc Luck
Really you can plug it in, get it on a dyno and see what happens.
You'll need a fuel pump first, i wouldnt even go near a dyno without one
Personally i think your wasting the dyno money, as the ECU isnt going to be anywhere near decent IMO.
oh ragex! yes it does have a blitz sticker on it....and two access stickers over the sides, plus an ecu number sticker on it....that help?
ok i have an essential tuned rom, i didnt use it cuz i had so many mods on my car but anyway, OPEN it up, and look in side what you are looking for is 2 kinds of these computers
one has a say 1 inch square chip on the board some times they have a glue on them it has tiny little legs all sides
THE other has a retangle chip also known as a EPROM it has little legs only on the long sides.
if u have the retangle one, you can actualy retune that computer, by your self if your confident OR take it to a few places i can recomend
P.s the square one can be tuned but no one will do them sorry....
i have a square one :laugh:
Edited by ragex
ragex,
would u mind giving me PM just in case it is the rectangle one.
cheers
i have a square one :)
Thats even sillier! You wont know what the AFR's look like.
If you hear it pining, then its way too bad of a tune.
If you wanna spend $80 and give it a go, no worries :)
It's silly to judge by what you hear too, because pinging and knocking is most often inaudible to humans in the first place.
It's only serious knocking that you hear. Sometimes it's already weakened the pistons by that time.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
