Is There Any Reliable Ceramic Coater In Adelaide?
Hi guys, it's been a long time since I posted in the SA section. I hope everyone is well, healthy and happy :)
I like to control the engine bay temp for my circuit GTR and looking at getting some ceramic coating for the rear housing of the T518Z's. Is there any pro or cons of doing so? Does the ceramic coat peel off?
Is there any reliable places in Adelaide that can do this?
Thanks in advance
hey Danh, hope things are going well for you in Qld!!
Yeah I have used the above place in Richmond and they were good. They do all the Pacemaker stuff and are located in the same building.
cant it be done in colours ... why i ask is i went to a powder coaters today to find out about doing my calipers and he said if they get to hot it will peel :) is this the same with all powder coaters or is there better powders then some
Hi Danh.
I've had a lot of ceramic coating done through Laurie at Ceramic Coat Australia. He is a good bloke and has always looked after me. I've had parts (such as dump pipe, turbine housing, timing covers, various brackets etc.) coated in both Cermakrome and black. Nil problems to report so far.
I think you'll find that the guys at CCA will recommend you use the higher temp' rated black coating for your turbine housings. The Cermakrome 'can' struggle to cope with the heat, especially in a circuit application. I've witnessed my turbine housing glowing a lovely bright red and the black coating took it in it's stride.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
