Hi guys,
Every morning and afternoon when I start my car up she squeaks like all buggery.
When I watch the PFC hand controller the squeaking doesn't stop till the volts read over 14 (takes a few seconds.) then she's quiet.
If I stop the engine, then restart immediately, it's fine. No squeaking. But goes to 14.7v almost immediately.
Should I tighten the alternator belt, and if so, by how much?
Or is something else wrong?
This problem only started happening after I got my car back from the panel shop after 4months...
https://www.sau.com.au/forums/topic/185246-squeaky-alternator-on-startup/
Actually you could take your air con belt off and switch it over to the alternator. They are all very simiar lengths.
Yes you do need to tighten it but also try putting some pure soap (not bath soap) on the inside of the belt. If the squealing comes back after getting it tight and the soap then replace it cos the squealing it's already done has damaged it.
OK, I think I'm going about this all wrong.
This long bolt was loose, almost falling out. I've tightened it. BUT, tightening it doesn't make sense to me. Having this tighter means a looser belt.
What am I supposed to do?
Loosen bolt 2, then pull the alternator towards the guard?
Tighten 1 slightly, but not all the way, bolt 2 is the tention thingy which when tighten moves the alternator towards the guard. (ie. tightens the belt). Tighten bolt 2 to the tention u want, then tighten bolt 1 to "lock" the position in.
  • 7 months later...
just a noob question...
but isnt the clutch fan ment to turn off like after awhile???
or nope becaoz it on the same belts as the alt. belt too.
so yeah?is it meant to turn off wen it gets to a normal operating temp?
becoz i just got my timing belt done..and i notice the next day, i can hear a squeaky sound from the front part of the engine..
so i assumed it was my timing belt...
but now being lik 4 days later..i dont think it is..
i think its the alt./fan belt
but could pwr str belt..
or air-con belt...
but unsure so far...
but one think i do notice is that the sound(squeaky sound) only appears to heard wen the enigne is at normal operating temp...
any ideas
what timing belt did you use?
me and a few of my friends have installed gates racing timing belts for our cars.
after the install, we noticed an extra whirring/squeaking/rotating sound added to the engine when the car is warm.
it's because of the new belts tightness, and over time it will loosen itself to it's perfect tension. if not, it will remain with that sound which isn't a bad thing. it might put a tiny bit of stress on your idler and tensioner, but i find it safer to have a belt a lil tight rather than a little loose.. especially at high revs.
Edited by dmr
Why would the clutch fan turn off, its on a belt that isn't going to stop while the engine is on :( ?
Anyway, the clutch fan will start slipping at higher RPM because the fan can't spin at too higher speed, and it will lock more and spin faster when the cars hot (at idle speed anyway).
well ive still got the same problem..lol
my cars done just over 1000k's with the new belt...
does anyone no how long it will b before the belt loosen to the original belt tension?
like as mention above and before...
people mentioning hear a squeak or sound from doing the t-belt..
and said it disapeared after a period of time..
if so..
how long is this time..lol
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
