Hi guys,
Every morning and afternoon when I start my car up she squeaks like all buggery.
When I watch the PFC hand controller the squeaking doesn't stop till the volts read over 14 (takes a few seconds.) then she's quiet.
If I stop the engine, then restart immediately, it's fine. No squeaking. But goes to 14.7v almost immediately.
Should I tighten the alternator belt, and if so, by how much?
Or is something else wrong?
This problem only started happening after I got my car back from the panel shop after 4months...
https://www.sau.com.au/forums/topic/185246-squeaky-alternator-on-startup/
Actually you could take your air con belt off and switch it over to the alternator. They are all very simiar lengths.
Yes you do need to tighten it but also try putting some pure soap (not bath soap) on the inside of the belt. If the squealing comes back after getting it tight and the soap then replace it cos the squealing it's already done has damaged it.
OK, I think I'm going about this all wrong.
This long bolt was loose, almost falling out. I've tightened it. BUT, tightening it doesn't make sense to me. Having this tighter means a looser belt.
What am I supposed to do?
Loosen bolt 2, then pull the alternator towards the guard?
Tighten 1 slightly, but not all the way, bolt 2 is the tention thingy which when tighten moves the alternator towards the guard. (ie. tightens the belt). Tighten bolt 2 to the tention u want, then tighten bolt 1 to "lock" the position in.
  • 7 months later...
just a noob question...
but isnt the clutch fan ment to turn off like after awhile???
or nope becaoz it on the same belts as the alt. belt too.
so yeah?is it meant to turn off wen it gets to a normal operating temp?
becoz i just got my timing belt done..and i notice the next day, i can hear a squeaky sound from the front part of the engine..
so i assumed it was my timing belt...
but now being lik 4 days later..i dont think it is..
i think its the alt./fan belt
but could pwr str belt..
or air-con belt...
but unsure so far...
but one think i do notice is that the sound(squeaky sound) only appears to heard wen the enigne is at normal operating temp...
any ideas
what timing belt did you use?
me and a few of my friends have installed gates racing timing belts for our cars.
after the install, we noticed an extra whirring/squeaking/rotating sound added to the engine when the car is warm.
it's because of the new belts tightness, and over time it will loosen itself to it's perfect tension. if not, it will remain with that sound which isn't a bad thing. it might put a tiny bit of stress on your idler and tensioner, but i find it safer to have a belt a lil tight rather than a little loose.. especially at high revs.
Edited by dmr
Why would the clutch fan turn off, its on a belt that isn't going to stop while the engine is on :( ?
Anyway, the clutch fan will start slipping at higher RPM because the fan can't spin at too higher speed, and it will lock more and spin faster when the cars hot (at idle speed anyway).
well ive still got the same problem..lol
my cars done just over 1000k's with the new belt...
does anyone no how long it will b before the belt loosen to the original belt tension?
like as mention above and before...
people mentioning hear a squeak or sound from doing the t-belt..
and said it disapeared after a period of time..
if so..
how long is this time..lol
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
