Hey,
I'm in the process of installing my guages on my R33 GTST. I have installed the boost and water temp but I'm not too sure where the oil temp one goes.
The oil temp guage is the sort of one where you don't need to run an oil line through the car (stuff that!).
Any info would be great, thanks.
- Aron
https://www.sau.com.au/forums/topic/185363-oil-temp-guage/
Remove the oil filter from your engine, screw this sandwich plate onto the engine and then put the filter back on.
Gives you 2 or 3 places to put in sensors. Im oil temp and oil pressure guages off mine
Awesome as - thanks heaps ;)
https://www.sau.com.au/forums/topic/185363-oil-temp-guage/#findComment-3357053
  • 2 months later...
i got a sandwich plate like the one in the pic above but when screwing it in the main centre bolt(big one) its not long so it only screws in 1 thread to the block so its not really secure? anyone else have that problem?
Edited by Onthehunt
https://www.sau.com.au/forums/topic/185363-oil-temp-guage/#findComment-3494035
you need to get a thread adaptor thing to make it longer.
heres the link to it from silvia nsw.
www.mscn.com.au
turns out the length of the bolt on my housing was standard. i went to SSS and got another one and its the same length.
seems to me that the justjap centre nipple is designed to only screw on for 1.5 to 2 turns (which doesnt seem safe to me).
so i paid a visit to Motorsport Connections where they provided me with the same thread size nipple but longer so it bolts onto the housing safely.
only thing to note is that the thickness of the nipple has to be machined down on a lathe to the same thickness as the JustJap one to fit into the sandwich plate.
im at work so i cant link up the pictures.
https://www.sau.com.au/forums/topic/185363-oil-temp-guage/#findComment-3504852
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
