Hey all,
Im upgrading a few things on my car, new pc, SEBC, Front mount, Twin dumps and highflow..
Im worried with all the flow and boost that ill need a Fuel pump or fuel cut defender to keep up with it all.
No im confused with the both of them, I assume the fuel cut defender will prevent fuel from cutting? and work with the stock pump?
and a aftermarket or gtr fuel pump will just drill fuel down the lines to make sure enough is being pumped?
If anyone could help out would be great.
btw ive read abit on pumps and if people suggest I get one rather than a FCD than im looking at Nismo, HKS and stock GTR one.
Anyone comment on my choices??
Thanks beforehand.
Nathaniel
Edited by DECIM8
https://www.sau.com.au/forums/topic/185382-fuel-pump-or-fcd/
Suggest you get a WALBRO pump, there about $160 delivered via express post from SLIDE, and are direct replacement of the standard.
GTR pump isn't a direct fit, but will flow 300rwkw if in good condition.
Fuel pump is always a good upgrade when increasing boost.
Sorry from all the testing ive seen on fuel pumps walbro is the worst as it does not flow at high rpm (not sure if that only applies to big kw)
Quiet a lot of high power cars (mid to high 200rwkw) running WALBRO's.
Maybe they weren't original WALBRO pumps?
The ones that SLIDE sell flow 255lph, and if I am not wrong thats more than a BOSCH 040?..
I cant back up my claim either, however someone high in the food chain did mention is on sau... forget who..
Anyway are the walbro loud? im pretty sure my mate has one on his wrx and it sounds like a freight train .. its either walbro or bosch??
Cant remember how loud the WALBRO's are , I'm ordering one tomorrow and will have it in by Friday so I can let you know then.
GTR pump is fair loud, thats whats I have in my car right now.
The BOSCH 040 is very loud, you can hear it from a while away.
Edited by abu
might be bosch then, because I was in my car, 4 cars away windows closed and he had the ignition on (400kw wrx) and all I could hear was whining.. so yeah :P
Ok so what else ppl recommend then? Walbro everyone?
I put a walbro in last week. I bought it from slide, the same one abu is talking about. I rubber mounted mine so its not noisy. You can hear it, but its not loud at all. The exhaust note drowns out the sound.
The Mafia cleared up a few Q's for me here about a week ago about flow etc.
http://www.skylinesaustralia.com/forums/in...p;#entry3337787
As for FCD and fuel pump. They're both totally different things that do totally different jobs. The fuel pump supplies fuel, the FCD is a AFM signal bender to prevent the ecu from going into panic mode.
Someone correct me if I'm wrong.
Can't go wrong with a nismo pump. It'll support plenty of power. I've heard one before, It's not "quiet" but not loud either. Just be prepared to fork the $$ out for it.
The tomei and nismo pumps are the same item. Just different names.
Edited by KeyMaker
Nismo and Tomei pump kits are supposed to be the same item from what i've heard with the Tomei being alot cheaper so get the Tomei if going for one of those 2.
If you going to fit it yourself, the above pumps are a sinch to install. Check the DIC thread on "easiest Fuel Pump upgrade ever"
Walbros and Bosches have some small adjustments to the bracket, and I've seen some wrapped in a sort of rubber sock to prevent the noise but check on the rubber as some can break down in fuel.
If you're getting a Power FC (you said a new PC????), forget the fuel cut defender.
Covers everything a FCD does, in fact the FCD is about the cheapest Air Fuel Computer around to fool the ECU, like someone else said before. Forget em, cheap and nasty upgrade. Either full Power FC (highest recommendation) or a SAFC or similar...or Greddy Emanage or any other full replacement ECU
in my experiences walbro pumps in turbo cars are not reliable. they seem to drastically run out of flow as the fuel pressure rises (with boost). I personally wouldn't use one on any car I value. good fuel supply is one of the most important things to the life of an engine so bearing that in mind the price of a nismo pump is a wise investment.
What about BOSCH 040 pumps, how do they compare?
I am getting put off WALBRO the more I read about it. So many mixed responses and view that I don't know who to believe. Due to so much mixed repsonses though, it couldn't possibly worth it..
I am thinking about going BOSCH 040, how do they compare? Good reliable pump?
I'm not worried about installation, just the pump quality it self. I don't really want to spend $300+ for a TOMEI/NISMO.
well personally I wouldn't be skimping on my fuel pump. but it's your money and your choice. I'm still surprised that people such as your good self continue to reccomend walbro. I don't know if you have used one or not but the number of failures I have witnessed means I wouldn't ever buy one. bosch pumps well they have had a lot of bad press too with failures. some of that came from copy pumps being sold, and I think some was down to poor installation how much was actual poor quality pumps I don't know. but I do know this. I have never heard of one single nismo pump failure. granted there may not be as many out there, but still....
my car pushes 300hp at wheels and i have a walbro 255 lph fuel pump (using 550cc injectors) and its fine to me... i recently replaced it thinking it was faulty but found out after replacing it it was wiring... one thing to remember with the walbro fuel pumps they need more than 12v i think its 13.something with a relay to be running at full compacity, thats where people go wrong and shoot the walbro's down, also there are copys out there that arnt genuine (be aware)...
from my experience its a good replacement, and as said above you can get them for $160 delivered and are easy to install
make sure you get the right walbro pump for what you need as there are some different ones. you may need to seek pro advice.
oh and as far as sound goes. they prime a bit loud but cant hear it running under exhaust note... and give a nice note... noticed changing my walbro with the exact same part number it altered the note (dunno there... may have been because the filter is new and the other was a little grubby and with the newer filter it flows better)...
I have seen/been in a few cars running WALBRO pumps. One of those has been running a WALBRO for over 2 years with no issues or signs of failure. It is also making over 200rwkw, and has been for the period of time the fuel pump has been installed.
Also from what I have red in the forced induction section "turbo upgrades for RB20/25" many people are using WALBRO pumps and making well over 200rwkw.
However, I am reading mixed responses from people such as your self who say they have witnessed plenty of WALBRO failures, and then from others like 'THE MAFIA' who say WALBRO's are fine, I am running 300rwkw on one.
There is too much controversy for me to now agree/disagree that WALBRO's are good/bad now, but I am going off personal experience. I know now I will not be going with a WALBRO pump, as an item should not have so much mixed responses. It is either good or its not. It is telling me that either the quality of the pump is not consistent or it's just the luck of the draw, some fail some don't?
As for BOSCH 040, I have run 3 of them in 3 different cars with no issues but like you said, have also heard about them failing...
Now that you mention it, I haven't heard of a single TOMEI/NISMO pump failing, why? I don't know... However, it seems like they are doing something right.
All my recommendations/opinions are based on personal experience or from what I have read, so that is why I was recommending the WALBRO pump.
Edited by abu
This is exactly what I was talking about lol
However, I am reading mixed responses from people such as your self who say they have witnessed plenty of WALBRO failures, and then from others like “THE MAFIA” who say WALBRO’s are fine, I am running 300rwkw on one.
There is too much controversy for me to now agree/disagree that WALBRO’s are good/bad now, but I am going off personal experience.
Edited by abu
well like I said a lot of the reason you hear about walbro and bosch failures comes down to poor install. you will never get that with nismo or tomei pumps are they are 100% direct fit, even down to plugging into the existing wiring so you imediately elliminate the chance of installation related failures. but there are too many other cases for me to risk using one personally.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
