i got fined the other nite for having my number plate on the LHS of the car (33gtst) $240 dollars later i called the transport department and they said that the plate can be anywhere on the front of the car as long as it is viewable from a 45' angle??? is there anyway of getting out of this redulious fine without going to court??
https://www.sau.com.au/forums/topic/185493-help/
no it is better going to court buddy, just provide documented evidence from the transport company that states that you are allowed to have your plate there. Provide evidence from mitsubishi about the late model evo which has it there....chances are if you provide this evidence..you may not need it, but the judge my look at it and WTF are you wasting my time with this and throw it out.
Best going to court buddy.
https://www.sau.com.au/forums/topic/185493-help/#findComment-3356201
You need to take a very scientific approach to beating this fine...
Park your car at a shopping centre right on the white line under the middle of the car, then measure a 45 degre angle from the front of the car in both directions.
Be very accurate, mark the 45 degre line with chalk on the concrete, make sure you take photos of you doing the measuring and the marking.
Then stand back 20 metres or so and take a photo of the front of your car with your camera from both lines.
If you can see the number plate easily in both photos you will win the case easily, if you cannot see it in one of the photos then dont bother going to court, just pay the fine.
Does this make any sence?
https://www.sau.com.au/forums/topic/185493-help/#findComment-3356274
Dude was it a state traffic task force officer that fined you? or a normal copper? i had a defect that i thought was stupid/irrelevant/bullshit and i wrote in to the officer in charge @ STTF with all my evidence and everything and he wrote back saying no action was required on my behalf and he would look into it further and get back to me, its now 3 months or so later and i havent heard back from him but i'm sure when/if i hear back he will favour my way, you should do the same
https://www.sau.com.au/forums/topic/185493-help/#findComment-3357743
The ONLY way things like this will stop happening is for everyone who cops a bullshit fine/harassment etc to go thru the inconvenience of taking it thru court, turn up well armed & have the facts give the beak no option but to throw it out.
Only then will some sort of precedent be set & hopefully the cowboys within the service will be finally told to back the f**k off & leave us alone when it comes to this sort of petty crap.
There is no doubt that police have their place in the world, but sometimes some of them need to be reminded exactly where that place is........
https://www.sau.com.au/forums/topic/185493-help/#findComment-3358375
I really don't see how you can get done for having your plate offset to one side, if it is veiwable under their rules, then its legal.
I work on Alfa Romeo's, with the design of their front ends the factory mounting position for the number plate is offset on the left hand side of the vehicle, there was something back in 98 when the 156 was first released here that they had to change some rule allowing this, not 100% sure on what state of what the rule was, but still we have never had any customer complain of being fined for an offset number plate.
Find out the rules and if you are sweet under then take it futher.
Good luck
https://www.sau.com.au/forums/topic/185493-help/#findComment-3358501
i went and saw a transport department officer about it yesterady...he said good luck and told me to try and put it in the middle...f*@kin F#&K F*&Ks...looks like i just gotta pay because of being a minority.
https://www.sau.com.au/forums/topic/185493-help/#findComment-3359443
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
