Just for those interested -
The finer specs are:
Compressor Trim: 52
Turbine Trim: 84
Runs the same Turbine outlet Size as the HKS \ Garrett 3037
Compressor runs a Slightly Smaller inducer than the HKS \ Garrett 3037
These are all good things. This turbo would be very responsive and make about 280rwkw on 18psi.
Thats MY guess, but I may be wrong.
Looks like a extremely good setup turbo, so whoever buys this, I want you to start a thread and post your results.
Internal gated Rear housings can be picked up new from garret for $400 - $600.
https://www.sau.com.au/forums/topic/185607-sold/#findComment-3359970
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
