Hey guys
I've got a series 1 R33 wreck here, has a had a front end smack so the headlights/bumper/grille etc arent available, basically everything else is though
washer bottle & pumps - $20
radiator overflow bottle - $20
front swaybar - $30
rear bumper(maroon) - $50
Other bits:
roof lining (non sunroof model) good condition- $30
kick panels - $30/pair
Negotiable on some of this stuff. Pm me!
Thanks
rear rotors - $100 almost brand new, awesome nick SOLD
rear calipers&pads - $130 SOLD
rear 5 stud hubs & handbrakes + cables - $300 pair SOLD
stereo mounting brackets - $25 pair SOLD
rear left tail light -SOLD
parcel shelf SOLD
front seats in good nick - SOLD
larger dash surround w/ clock, hazards etc (had a tiny crack in it but i fixed it) - SOLD
front hubs, SOLD
upper control arms, front & rear - $25 each SOLD
castor/radius rods, near new aftermarket urethane bushes- $100 pair SOLD
stock rear shocks SOLD
rear clear Skyline fascia - $45 SOLD
complete boot interior, sides, carpet, top piece, as new - $70 SOLD
engine fuse box cover - $20 SOLD
leather handbrake boot, immaculate -$25 SOLD
seatbelts & buckles x5 (all of them)SOLD
climate control unit, as new condition SOLD
drivers side door trim - $50 SOLD
rear seats good nick - $50 SOLD
lowered front/rear king springs SOLD
complete set of 5 floormats, good condition SOLD
sun visors - $20 pair SOLD
3" catback exhaust system with resonator & cannon muffler, good sound -SOLD
S1 turbo(steel turbine) oil seal on compressor side is stuffed, very little shaft play -$100 SOLD
boost gauge - $40 SOLD
dash gear surround w/ leather boot and cig lighter - SOLD
bootlid with series 2 spoiler - SOLD
pair red GT badges, awesome condition - SOLD
front rotors - $100 SOLD
front calipers&pads SOLD
Edited by phatlavish
  • Replies 47
hey mate i got a series 2 r33
that has unfortunsately had an accident doing literally 20 ks'
my front quarter is gone
is the body in front the same as series 2
i no panels and stuff r
the waterbottle
is it the same as series 1
im after
radiator
front headlight drivers side (series 2)
waterbottle
fuse box cover
intercooler piping
maybe intercooler if cheap enough as i think mine may live not sure
bonnet
windsreen
front drivers side quarter cut
radiator support
maybe the cooler in front of the radiator( think its trans or something like that not sure)
i desperately need these parts
but money is a bit tight
:D
i wouldnt be in this predicament if the woman din have a spazz then leave and take my kidsas the the women left with the kids
an f**ked me over
but nyways
if u could help in anyway
or if there is any1 else out there that could help me with these parts and mif possible sum1 who could do the front quarter wed or wateva
cheap
please help out guys
cheers
im on msn or just email me any1
[email protected]
or call me
0422774359
help much appreciated
hey man how did the window's go? as in were they smooth going up and down etc? i'm after the drivers side regulator - don't really need the motor but if you'd prefer to sell together, let me know price.
cheers
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
