Hi , I have 33 with FMIC exhaust , hks pod, apexi neo AFC and putting in a Electronic boost controller . I was wondering where i can take it for dyno tuning in and around the brisbane area and does anyone have an idea of how much it will cost?
https://www.sau.com.au/forums/topic/185722-dyno-tuning-in-brisbane/
another tick for godzilla motorsport
have been to a number of tuners, and godzilla have been the stand out of them all and specializes in PFC and other aftermarket ecus. Tunes are performed with laptop software ( none of this handheld shit) to get the ultimate tune right through the rev range.
proof: Mark's 1000hp 8 sec r32 gtr. obviously shows that mark knows his shit and knows what hes doing.
do yourself a favour and do these first.
new spark plugs gapped to 0.8mm
new oil
new oil filter.
if you have stock coils, tape them up good with electrical tape.
the cost always ends up higher than what is quoted because you increase boost and power and you find the spark gives up and you hit missfire issues.
so unless you have split fire coils already, and don't want to spend $500+ on them or get the shits when you book in for a tune and they can't do it cause of spark issues, do the above first.
then they will only charge you for the install/tune.
got the quote today he said $500 with my basic mods, turbo back exhaust, 12psi boost, R34 cooler, pod, which seems pretty good
sparkies already gapped at 0.8, coils removed and refitted with high temp silicone (was getting miss firing at 10 psi, had heaps of coils cracks) , hmmm oil has only done a few thousand clicks should probably change it I guess but that depends on level of motivation.
400KW is #$%^%^ crazy!!!
Edited by SevenAngryPenguins
not sure, but it could just be the same time to tune... my old tuner who was an autronic specialist in sydney did mine within a reasonable time, same time as the power fc i had before. they probs just have a flat rate for tuning, as my old tuner did no matter what ecu... either way you'll be satisfied with the results, and its not that much considering they know hands down what they are doin i spose
hehe yeh 400 is fun, were gonna have it tuned up again just before jambo get around 450 out of it... got the gtr rear end going in now
ben...
Edited by 2BNVS
  • 3 weeks later...
I just moved in to tingalpa; so there are like 3 min away, wonder who much its going to cost to do the following,
Front mount (already got from crashed R33, with piping)
Dump / Front pipe
Hi / Low Boost setting - Dont want to spend on ECU still
Still running Nissan Coil pack though..
new oil
new oil filter.
i have stock coils and i didnt need to tape them up lol, when changing plugs the .8 gap is a good idea but u also want to go to a colder temp range. or was that hotter :thumbsup:
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
