Hey all
i did do a search but couldn't find anything that matches.
sorry for the long story
Mods to the car
Walbro fuel pump
HKS SSQV
r33 turbo
profec E01
FMIC
POD
standard computer
i have an odd issue with my car i have a random cut, when the car is hot i have a problem where the car will cut out, i thought it was the BOV cause it initially got this when changing gears after the BOV went off, so i tightened it right up and it seems to go away for a bit, i drove it from my place to QR about 1 hour with no problems. went out for my first run and when getting to 4000rpm i had the cut again, this happened about three times on my warm up lap but cleared up and was fine for the rest of the session.
now i go to start it up for the next session the car starts and then cuts out and stalls fire it up again and all is good, take it out for the warm up lap and it cuts out again at 4000rpm but then clears up and no problems again once the car is up to 85 degrees. same thing happens for the 3rd session. starts then dies and then fires again without a problem.
drive the car home and now i'm getting this cut when ever i give the car a bit, also happened when going up a hill and making a tight turn. anyway parked the car at home take it out the next day and all is ok.
the odd thing is the car was on the dyno the day before fuel pressure where good afr where rich but that is what i expected.
so if anyone has any ideas please let me know, i'm leaning towards fuel pump as it started to make more noise after the track day however it is now quiet. the only other thing i could think it is, is AFM but i'm at a loss. just wondering if anyone else has had a simliar issue?
https://www.sau.com.au/forums/topic/185758-rb20det/
  • 1 month later...
  • 1 month later...
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
