  • Replies 44
bov that vent to atmos DONT change air fuel ratios on cars that only have afm ie sky,silvia coz were the factory plum back go to is between turbo and afm. So the afm doesnt register it .2 i built a rb20t in a silvia in qld with a turbosmart type 2 bov for a customor in sydney and he went to the rta to get it tested on emission and it passed with flying colours with the bov type 2 on it remember it goes pod filter afm factory bov inlet pipe turbo
Greygirl1976 what colour is the car that you built that passed the NSW RTA tests? I go down there every two weeks and i would like to see it. My mate is STILL waiting for you to post where S.B.performance is so he can go and look at your conversions. I see you reply to everyone else we want to give you work but we would like to see some of your work before we part with any cash. Want is the guys name or his rego number so i can see his car (the one down south).????????????
Lambo, will try to answer ur questions, but im no expert. (dont even have a turbo car yet)
Originally posted by lambo
Does those BOV that vent excess air when the throttle is shut affect the air fuel ratio?
Yes, when the excess air is vented to atmosphere, a similar volume of air is sucked in through the filter, and through the air flow meter. The air flow meter (AFM) tells the engine to inject heaps of fuel to make up for increased volume of air. Therefore AFR goes rich and car puffs smoke and maybe even stalls.
Since the throttle is shut the air getting into the engine should be the same even without the BOV.
Its not the volume of air getting 'to' the engine thats important, but the flow through the AFM. When throttle is shut, no air (little air) is getting to engine. With no blow off valve or with a plumb back type BOV, air is recirculated back into intake, after the AFM, therefore making no difference to AFRs.
Isn't the job of the BOV is to pretect the intake turbine from blow back pressure from shutting the throttle abruptly.
Yes.. and it does. Both plumb back and atmo venting BOVs do this.
Hope that helped,
Rhett
Originally posted by greygirl1976
BLOW OFF VALVES DONT change air fuel ratio coz the blum back is after the afm go and have a look under the bonnet of a skyline turbo and u will see that the blum back is after the AFM .remember the afm only registers air goin one way
even ones that vent to atmosphere it dont change a.f ratio
Originally posted by raist60
umm yeah they do, just give up your wrong, k. the air dumps straight out after afm saw it, ecu gives fuel for air that has since been dumped to atmo, hence riching up your mixtures something bad.
u just said it after the afm thats correct so how does the afm register the air when the plum back is after the afm its simple it dont coz its after the air flow meter
air goes throu pod filter throu afm them meets up with plum back pipe is then in to turbo does everyone understand now or do i have to draw u a picture?
greygirl1973 maybe I can explain why raist60 is right,
With a atmo ventventing BOV the Afm has accounted for the fuel going into the motor, but not for it getting dumped to atmo thats why a atmo venting BOV will richen up the mixtures on a throttle release, this is however not harmful for the engine as it only happens for a moment it has been known to cause minor flooding of the engine causeing it to stall.
Mine only stalls if i go about 1-20km/h and slam on the anchors to stop quickly. Stalls maybe 2 times a month tops.
Check out this thread dude... maybe you have this problem if your car stalls when you jump off the gas and onto the brakes. Something to do with the fuel pump ground wire...
http://www.skylinesaustralia.com/forums/sh...s=&threadid=408
Cheers,
Andrew
hahaha, are we trying to re-write the laws of ECU physics or something here. Just give up man. Please for your sake. We can argue all day long but we are still right, serious dude we arent lying :P
ATMO BOVs make rich A/F ratios when venting... ECU has accounted for air it expects to end up in cylinder so adds fuel for air that has since been expelled through an ATMO BOV. Ie the fuel gets dumped but the air never made it into cylinder therefore higher fuel ratio to air, therefore lower A/F Ratios. Hoora!11
hahaha, are we trying to re-write the laws of ECU physics or something here. Just give up man. Please for your sake. We can argue all day long but we are still right, serious dude we arent lying :)
ok time to talk technical
raist60 as u dont understand what im talkin about ive just learnt about this at tafe {yes im a mechanic} ok here goes
all fuel injected cars run lean when u snap the throttle off. The tps tells the ecu to shut off fuel to the injectors only for 1/100th of a second to allow for the excess fuel to burn off in the engine as this is happening the oxygen sensor is reading the exhaust gasses and tells the ecu what is goin on as soon as the o2 sensor sences a weak mixture it tells the ecu to flow more fuel so when a bov vents to atmo or not it discludes that air coz the tps has told the ecu to shut fuel off which in turn runs the engine lean
if u dont beleve me take your car to a automotive workshop and do a test on the gass anailzer with a bov plumed in and a bov venting to atmo u will see it for yourself these computers r allways learning {called fuzzy logic} all fuel ratios r controled by the o2 sencer
But what about the Air Flow Meter? you didn't mention that... and if that plays no part in it, why do we have them?!?!
And why is it that when you see a turbo car with an atmo BOV racing, it blows black smoke on the gear changes?
If the air that is already measured by the air flow meter and the signal is then passed on to the ECU so it can inject the right amount of fuel, then when the air is not there to burn with the fuel as it's been vented, then you'd expect more fuel/less air... richer mixture for that point. Maybe like you say the computer stops the fuel being inject the instant the throttle is closed, but what about the air that was measured before the it was closed?
Andrew
gerygirl1976
Yeah, Where is the AFM in your exellent but incorrect (when applied to skylines anyway) explanation?
You may need to go back to tafe and recover the module on efi and fuel mixtures.
ok time to talk technical Are you sure what you said isn't applied to a map type efi only? because what you said dose sound correct for map sensor efi.
To take the point one further, I have perviously fixed the stalling due to overrich with an atmo bov problem by adjusting the air bypass valve at the back of the inlet.
the turbo cars racing blowing a puff of black smoke r soo fuelld up with too much fuel to start off with my car does this and i dont have a bov on my car and as for the afm
it plays its part but when the throttle is snaped shut the computer kinda ignores the afm for an 1/8th of a second coz theres all this fuel in the engine but no air comming in{throttle is shut} so the ecu stuts off the injectors for that 1/8th of a second to burn off the fuel and the air in the plemun chamber then when the o2 sensor senses that the excess fuel has burnt off the o2 sensor tell the ecu that the engine is very lean and turn the injectors back on and at the same time starts talkin to the afm
all the above happens in less than second
if u stick a sniffa up the exhaust and do this as soon as the throttle is snapped shut the anlizer screen spikes to the rich scale about 12to13-1 for 1/8 of a sec then leans out to about 17to18-1 and the scale flattens out back to 15to 14.7to1 this all happens in under a second providing the car isnt runnin rich to start off with all the above happens the same way even with a na motor do u need me to explain more
and im not trying to b a smart ass im trying to help so every 1 can understand what goes on
Mate I run A Link Lambda on my car and before my new ecu it stayed rich for more than 2 sec on back off (blow Off Venting to atmo) on the dyno it run so rich it was off the scale 10:1 and richer.
By what you are saying the ecu ignores the afm for
1/8 of a second well it takes longer than that for a bov to dump to atmo therfore the mixtures could go rich.
it takes 1/8 of a sec for the pressure to build high enough for the bov to open.
most ecu's only sample every 1/8 sec or 125ms
You are not correct with what you are saying Sorry...
and aren't most O2 sensors either hi/low reading??? used mostly for the warm up period? wouldn't you'd need a wide band O2 sensor to read the air/fuel mixes properly... and as these are expensive i wouldn't have thought they'd be a factory item.
thats right they only read between 12 - 14 or so, and only once the motor is hot enough,
A wide band O2 sensor is around the $500 mark
Hey Theres another reason why the ecu cant use the O2 sensor as described by gerygirl1976 the signal would be out of range the factory ecu only uses its signal during cruse mode not throttle on or throttle off.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
